决策报表打开异常
决策报表打开白屏,查看异常日志如下,有知道具体是什么原因的的么。
2022-03-05 11:43:15
严重:11:43:15 http-nio-8075-exec-7 ERROR [standard] 错误代码:11201000 JS抛错
具体错误:config type cannot be null.
错误堆栈:Error: config type cannot be null.
    at Object.FR.createWidget (http://localhost:8075/webroot/decision/view/form?op=emb&resource=finereport.js&inter=zh_CN&__fr_locale__=&__v__=2021.09.23.16.20.11.612&jsVersion=1646438947200:556:496)
    at sb.createConfig2Form (http://localhost:8075/webroot/decision/view/form?op=emb&resource=finereport.js&inter=zh_CN&__fr_locale__=&__v__=2021.09.23.16.20.11.612&jsVersion=1646438947200:3344:167)
    at sb._init (http://localhost:8075/webroot/decision/view/form?op=emb&resource=finereport.js&inter=zh_CN&__fr_locale__=&__v__=2021.09.23.16.20.11.612&jsVersion=1646438947200:3343:472)
    at sb.FR.OB (http://localhost:8075/webroot/decision/view/form?op=emb&resource=finereport.js&inter=zh_CN&__fr_locale__=&__v__=2021.09.23.16.20.11.612&jsVersion=1646438947200:575:176)
    at sb (http://localhost:8075/webroot/decision/view/form?op=emb&resource=finereport.js&inter=zh_CN&__fr_locale__=&__v__=2021.09.23.16.20.11.612&jsVersion=1646438947200:532:193)
    at new sb (http://localhost:8075/webroot/decision/view/form?op=emb&resource=finereport.js&inter=zh_CN&__fr_locale__=&__v__=2021.09.23.16.20.11.612&jsVersion=1646438947200:532:193)
    at Object.complete (http://localhost:8075/webroot/decision/view/form?op=emb&resource=finereport.js&inter=zh_CN&__fr_locale__=&__v__=2021.09.23.16.20.11.612&jsVersion=1646438947200:5360:16852)
    at Object.b.complete (http://localhost:8075/webroot/decision/view/form?op=emb&resource=finereport.js&inter=zh_CN&__fr_locale__=&__v__=2021.09.23.16.20.11.612&jsVersion=1646438947200:507:317)
    at cc (http://localhost:8075/webroot/decision/view/form?op=emb&resource=finereport.js&inter=zh_CN&__fr_locale__=&__v__=2021.09.23.16.20.11.612&jsVersion=1646438947200:116:69)
    at Object.fireWith (http://localhost:8075/webroot/decision/view/form?op=emb&resource=finereport.js&inter=zh_CN&__fr_locale__=&__v__=2021.09.23.16.20.11.612&jsVersion=1646438947200:117:455)
2022-03-05 11:43:16
正常:11:43:16 SessionClose-55-worker-1 INFO [standard] Session closed: b8467d3f-e8fd-4255-953e-1ad0e388c29a
FineReport yzm806890 发布于 2022-3-5 11:47 (编辑于 2022-3-5 11:47)
发布于2022-3-5 11:49
备份一下模板后。把里面所有js先删除。。然后再看。。。一个个测试是哪一段js导致的。。就是比如先删除后。。再一段一段的加。。。直到加到哪一段的js错误
  • 399浏览人数
  • 最后回答于:2022-3-5 11:49
