数据集问题
为什么会出现双倍的列名呢(ORACAL数据库)
SELECT '当日' as types,a.xmthdlx,count(1) as n FROM
(select
requestid,
czrq,
jxs,
czmc,
case when hdlx = '1' then '车展' else to_char(hdlx) end as hdlx,
case when xmthdlx = '1' then '小红书'
when xmthdlx = '0' then '抖音'
else to_char(xmthdlx) end as xmthdlx
from formtable_main_40
where czrq = '${dates}') a
INNER JOIN
select requestid,workflowid,status from workflow_requestbase
where 1=1
-- and (status = '出口7' or status = '结束')
and (workflowid = 3022 OR workflowid = 42022) ) b
ON a.requestid = b.requestid
group by a.xmthdlx
union ALL
SELECT '当月' as types,a.xmthdlx,count(1) as n FROM
(select
requestid,
czrq,
jxs,
czmc,
when xmthdlx = '2' then '微信'
where czrq >=  to_char(TO_DATE('${dates}','YYYY-MM-DD'),'yyyy-mm-')||'01') a
INNER JOIN
where 1=1
and ( workflowid = 3022  OR workflowid = 42022)
) b
group by a.xmthdlx
union ALL
SELECT '累计' as types,a.xmthdlx,count(1) as n FROM
(select
requestid,
czrq,
jxs,
czmc,
-- where czrq >=  to_char(TO_DATE('${dates}','YYYY-MM-DD'),'yyyy-mm-')||'01'
) a
INNER JOIN
where 1=1
) b
group by a.xmthdlx
FineReport ZxxT 发布于 2022-9-1 10:23 (编辑于 2022-9-1 10:24)
发布于2022-9-1 10:25
你这个是卡了,重启设计器看看
你查询数据是对,正常同样列名会报错的
  • 216浏览人数
  • 最后回答于:2022-9-1 10:25
