出货收款金额分摊SQL处理方案
使用场景是销售出货收款分摊。一个销售单有多笔出货,针对这个销售单有多笔收款,数据处理需要将收款和出货关联在一起。
要求出货按时间排序,将不同时间的收款金额分别摊平到出货金额上,先出货的用最早一笔收款去摊平,该笔收款有余额则给下一笔出货使用,如果余额不足则使用下一笔收款继续摊平这笔出货,类推、,
当第一笔收款用尽,就用第二笔收款,第二笔收款用尽,用第三笔收款。计算出每笔出货中分摊的收款金额和收款日期。
SQL 一口十个松花蛋 发布于 2024-8-20 11:02 (编辑于 2024-8-20 13:30)
一口十个松花蛋Lv5见习互助
发布于2024-8-20 13:31
已解决,用了游标
JL98Lv6中级互助
发布于2024-8-20 13:33(编辑于 2024-8-20 13:34)
SQLSERVER 存储过程
CREATE PROCEDURE dbo.AllocatePaymentsToShipments
AS
BEGIN
    SET NOCOUNT ON;
    -- 假设存在两个表:Shipments 和 Payments
    -- Shipments 表有 ShipmentID, Amount, ShipmentDate
    -- Payments 表有 PaymentID, Amount, PaymentDate, SalesOrderID
    -- 临时表存储结果
    CREATE TABLE #Result (
        ShipmentID INT,
        AllocatedAmount DECIMAL(18, 2),
        AllocatedPaymentDate DATE
    -- 变量用于跟踪当前处理的Payment和余额
    DECLARE @CurrentPaymentID INT, @CurrentPaymentAmount DECIMAL(18, 2), @RemainingPaymentAmount DECIMAL(18, 2), @CurrentPaymentDate DATE;
    -- 初始化变量
    SET @RemainingPaymentAmount = 0;
    -- 假设Payments已按PaymentDate排序,Shipments已按ShipmentDate排序
    -- 使用游标或循环遍历Payments和Shipments,这里使用CTE和窗口函数模拟
    -- 假设Payments已经根据SalesOrderID和PaymentDate排序
    WITH SortedPayments AS (
        SELECT
            PaymentID,
            Amount,
            PaymentDate,
            ROW_NUMBER() OVER (PARTITION BY SalesOrderID ORDER BY PaymentDate) AS PaymentOrder
        FROM Payments
    SortedShipments AS (
        SELECT
            ShipmentID,
            Amount,
            ShipmentDate,
            ROW_NUMBER() OVER (ORDER BY ShipmentDate) AS ShipmentOrder
        FROM Shipments
    Allocations AS (
        -- 这里需要一个复杂的逻辑来逐步分配付款,这里仅展示框架
        SELECT
            sp.ShipmentID,
            sp.Amount,
            sp.ShipmentDate,
            CASE
                -- 分摊逻辑,这里需要根据实际情况实现
                WHEN @RemainingPaymentAmount >= sp.Amount THEN sp.Amount
                WHEN @RemainingPaymentAmount > 0 THEN @RemainingPaymentAmount
                ELSE 0
            END AS AllocatedAmount,
            CASE
                WHEN @RemainingPaymentAmount >= sp.Amount THEN @CurrentPaymentDate
                WHEN @RemainingPaymentAmount > 0 THEN @CurrentPaymentDate
                ELSE NULL
            END AS AllocatedPaymentDate,
            -- 更新剩余金额的逻辑
            @RemainingPaymentAmount = CASE
                WHEN @RemainingPaymentAmount >= sp.Amount THEN @RemainingPaymentAmount - sp.Amount
                WHEN @RemainingPaymentAmount > 0 THEN 0
                ELSE @RemainingPaymentAmount
            END
        FROM SortedShipments sp
        CROSS APPLY (
            SELECT TOP 1 @CurrentPaymentID, @CurrentPaymentAmount, @CurrentPaymentDate
            FROM SortedPayments
            WHERE SalesOrderID = -- 假设有方式关联SalesOrderID到Shipment
                AND PaymentOrder = (
                    SELECT MAX(PaymentOrder)
                    FROM SortedPayments
                    WHERE SalesOrderID = -- 关联SalesOrderID
                        AND @RemainingPaymentAmount < Amount OR @RemainingPaymentAmount = 0
            ORDER BY PaymentOrder
        ) ca
        -- 注意:这里的CROSS APPLY只是示意,实际实现会更复杂
    -- 将分配结果插入到临时表
    INSERT INTO #Result (ShipmentID, AllocatedAmount, AllocatedPaymentDate)
    SELECT ShipmentID, AllocatedAmount, AllocatedPaymentDate
    FROM Allocations
    WHERE AllocatedAmount > 0;
    -- 后续处理,比如从临时表返回结果
    SELECT * FROM #Result;
    -- 清理临时表
    DROP TABLE #Result;
END
GO
  • 194浏览人数
  • 最后回答于:2024-8-20 13:34
