sql语句错误提示:缺少右括号。可以麻烦哪个大佬帮忙看看指点一下嘛?谢谢!
select i.lottable02 供应商代码,
            sr.company 供应商名称,
            o.consigneekey 发货地,
     TO_CHAR(o.requestedshipdate + 8 / 24, 'yyyy-mm-dd hh24:mi:ss') 需求时间,
                                   o.notes 需求订单,
                                   i.sku 物料编码,
                                   s.susr1 物料组,
                                   s.descr 物料名称,
                                   i.lottable08 寄存属性,
                                   sum(i.qty) 数量
  from (select * from itrn where trantype = 'WD') i  join sku s on i.sku = s.sku
where exists(select * from storer as sr where i.lottable02 = sr.storerkey and type = 2) and exists(select * from orders as o where o.orderkey = substr(i.sourcekey, 0, 10))
neyhig 发布于 2021-7-7 10:54
发布于2022-1-9 20:56
SELECT
i.lottable02 供应商代码,
sr.company 供应商名称,
o.consigneekey 发货地,
TO_CHAR (o.requestedshipdate + 8 / 24,'yyyy-mm-dd hh24:mi:ss') 需求时间,
o.notes 需求订单,
i.sku 物料编码,
s.susr1 物料组,
s.descr 物料名称,
i.lottable08 寄存属性,
sum(i.qty) 数量
FROM
SELECT
FROM
itrn
WHERE
trantype = 'WD'
) i
JOIN sku s ON i.sku = s.sku
WHERE
EXISTS (
SELECT
FROM
storer AS sr
WHERE
AND type = 2
AND EXISTS (
SELECT
FROM
orders AS o
WHERE
group by
    i.lottable02,
sr.company,
o.consigneekey,
TO_CHAR (o.requestedshipdate + 8 / 24,'yyyy-mm-dd hh24:mi:ss'),
o.notes,
i.sku,
s.susr1,
s.descr,
i.lottable08
烟尘Lv6高级互助
发布于2021-7-7 10:56
代码不全,没有group by
  • neyhig neyhig(提问者) 加上group by之后还是缺失右括号
    2021-07-07 11:12
山东郭德纲Lv2见习互助
发布于2021-7-12 14:24
这一块  +8 / 24?  是+3?  这个时间可以直接运算的?
  • 488浏览人数
  • 最后回答于:2022-1-9 20:56
