展开树子节点之和为父节点的值,怎么处理
FineReport fangqing 发布于 2021-7-28 16:32
发布于2022-1-29 13:17
发布于2021-7-28 16:41
给你一个SQL
--测试数据
with area(id,"name",f_id,leve) as (
  select  1,'中国',0,1 union all
  select  2,'湖北',1,2 union all
  select  3,'武汉',2,3 union all
  select  4,'云贵',1,2 union all
  select  5,'云南',4,3 union all
  select  6,'贵阳',4,3 union all
  select  7,'云南子区',5,4 union all
  select  8,'贵阳子区',6,4 union all
  select  9,'蔡甸',2,3
), "table"(id,area_id,"money") as (
  select  1,3,10 union all
  select  2,9,5 union all
  select  3,7,20 union all
  select  4,8,30
--使用cte递归求出每个节点的路径
,t(id,f_id,"name","level",fullpath) as (
  select a.id,a.f_id,a."name",a.leve,cast(a.id as varchar(max))
  from area a
  where a.leve=1
  union all
  select b.id,b.f_id,b."name",b.leve,t.fullpath+'->'+cast(b.id as varchar(max))
  from area b
  inner join t on t.id=b.f_id
--汇总统计每个节点的金额
select t.id,t."name",t."level",sum(c."money") as "money"
from t
inner join t t1 on charindex(t.fullpath,t1.fullpath)=1
inner join "table" c on c.area_id=t1.id
group by t.id,t."name",t."level"
order by t.id
  • fangqing fangqing(提问者) 如果用帆软报表的功能来实现呢?不用SQL来做
    2021-07-28 16:58
  • Z4u3z1 Z4u3z1 回复 fangqing(提问者) 写不出
    2021-07-28 17:01
  • 334浏览人数
  • 最后回答于:2022-1-29 13:17
