我用sql查询表结构,在navicat里面正常运行,可以查出表结构,fr的数据连接是正常的,把这段sql放进去就报错了,错误代码显示11300001,有没有人知道是什么原因? 这是查询表结构的SQL: SELECT (case when a.colorder=1 then d.name else null end) 表名, ( d.name) 表名2, a.colorder 字段序号,a.name 字段名, (case when COLUMNPROPERTY( a.id,a.name,'IsIdentity')=1 then '√'else '' end) 标识, (case when (SELECT count(*) FROM sysobjects WHERE (name in (SELECT name FROM sysindexes WHERE (id = a.id) AND (indid in (SELECT indid FROM sysindexkeys WHERE (id = a.id) AND (colid in (SELECT colid FROM syscolumns WHERE (id = a.id) AND (name = a.name))))))) AND (xtype = 'PK'))>0 then '√' else '' end) 主键,b.name 类型,a.length 占用字节数, COLUMNPROPERTY(a.id,a.name,'PRECISION') as 长度, isnull(COLUMNPROPERTY(a.id,a.name,'Scale'),0) as 小数位数,(case when a.isnullable=1 then '√'else '' end) 允许空, isnull(e.text,'') 默认值,isnull(g.[value], ' ') AS [说明] FROM syscolumns a left join systypes b on a.xtype=b.xusertype inner join sysobjects d on a.id=d.id and d.xtype='U' and d.name<>'dtproperties' left join syscomments e on a.cdefault=e.id left join sys.extended_properties g on a.id=g.major_id AND a.colid=g.minor_id left join sys.extended_properties f on d.id=f.class and f.minor_id=0 --where b.name is not null WHERE d.name='A01' --如果只查询指定表,加上此条件 如果去掉则是查询全部的 order by a.id,a.colorder |
