Doris数据库连接失败
报错信息:
com.mysql.jdbc.exceptions.jdbc4.CommunicationsException: Communications link failure The last packet sent successfully to the server was 0 milliseconds ago. The driver has not received any packets from the server. at sun.reflect.GeneratedConstructorAccessor492.newInstance(Unknown Source) at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45) at java.lang.reflect.Constructor.newInstance(Constructor.java:423) at com.mysql.jdbc.Util.handleNewInstance(Util.java:403) at com.mysql.jdbc.SQLError.createCommunicationsException(SQLError.java:990) at com.mysql.jdbc.MysqlIO.<init>(MysqlIO.java:335) at com.mysql.jdbc.ConnectionImpl.coreConnect(ConnectionImpl.java:2187) at com.mysql.jdbc.ConnectionImpl.connectOneTryOnly(ConnectionImpl.java:2220) at com.mysql.jdbc.ConnectionImpl.createNewIO(ConnectionImpl.java:2015) at com.mysql.jdbc.ConnectionImpl.<init>(ConnectionImpl.java:768) at com.mysql.jdbc.JDBC4Connection.<init>(JDBC4Connection.java:47) at sun.reflect.GeneratedConstructorAccessor220.newInstance(Unknown Source) at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45) at java.lang.reflect.Constructor.newInstance(Constructor.java:423) at com.mysql.jdbc.Util.handleNewInstance(Util.java:403) at com.mysql.jdbc.ConnectionImpl.getInstance(ConnectionImpl.java:385) at com.mysql.jdbc.NonRegisteringDriver.connect(NonRegisteringDriver.java:323) at com.fr.third.alibaba.druid.pool.DruidAbstractDataSource.createPhysicalConnection(DruidAbstractDataSource.java:1461) at com.fr.third.alibaba.druid.pool.DruidAbstractDataSource.createPhysicalConnection(DruidAbstractDataSource.java:1525) at com.fr.third.alibaba.druid.pool.DruidDataSource$CreateConnectionThread.run(DruidDataSource.java:2165) Caused by: java.net.ConnectException: Connection timed out: connect at java.net.DualStackPlainSocketImpl.connect0(Native Method) at java.net.DualStackPlainSocketImpl.socketConnect(DualStackPlainSocketImpl.java:79) at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:350) at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:206) at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:188) at java.net.PlainSocketImpl.connect(PlainSocketImpl.java:172) at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392) at java.net.Socket.connect(Socket.java:589) at com.mysql.jdbc.StandardSocketFactory.connect(StandardSocketFactory.java:211) at com.mysql.jdbc.MysqlIO.<init>(MysqlIO.java:299) ... 14 more
配置如图:
FineReport liuday 发布于 2021-10-19 11:12
发布于2022-4-15 17:21
[平台]Doris数据连接-https://help.fanruan.com/finereport/doc-view-4422.html
15922204585Lv6高级互助
发布于2021-10-19 11:19
mysql服务是否开启,能查询sql吗?https://blog.csdn.net/stupidkid521/article/details/87257586
  • liuday liuday(提问者) 服务器开启了,我使用dbeaver可以连接上
    2021-10-19 11:24
  • liuday liuday(提问者) 在dbeaver上连接的可以正常查询SQL
    2021-10-19 11:27
  • 15922204585 15922204585 回复 liuday(提问者) 那不太清楚了,没遇到过
    2021-10-19 11:28
HarderLv6见习互助
发布于2021-10-19 13:15
本地能打开mysql数据库么?错误信息好像显示驱动问题
  • 2067浏览人数
  • 最后回答于:2022-4-15 17:21
