如下sql我取到的dlsj没问题,但tcsj会变成9号我想取从3号到9号的每一天的最大时间和最小时间
如下sql我去到的dlsj没问题,但tcsj会变成9号我想取从3号到9号的每一天的最大时间和最小时间,该怎么实现
sql:
SELECT TOP (10000000) [ryid]
      ,[ryxm]
      ,min([dlsj])as[dlsj]
      ,max([tcsj])[tcsj]
  FROM testS
  where [dlsj] between '2023-02-03' and '2023-02-09'
  --and dlsj
  group by ryid,ryxm
  order by dlsj desc
数据库数据如下:
数据集如下:
SELECT  [ryid]
      ,[ryxm]
      ,max([tcsj])[tcsj]
  FROM testA
where dlsj is not null
${if(len(kssj)==0,""," and dlsj>='"+FORMAT(DATEDELTA(kssj,-1),"yyyy-MM-dd 20:30:00")+"'")}
${if(len(kssj)==0,""," and ReqTime<='"+FORMAT(kssj,"yyyy-MM-dd 20:30:00")+"'")}
FineReport Vessel1213 发布于 2023-2-14 14:42 (编辑于 2023-2-14 15:34)
发布于2023-2-14 14:46
表结构都不清楚不好猜啊
数据库是:oracle?SqlServer?还是mysql 也不清楚
  • Vessel1213 Vessel1213(提问者) sqlserver
    2023-02-14 14:46
  • Z4u3z1 Z4u3z1 回复 Vessel1213(提问者) 表结构呢?
    2023-02-14 14:53
  • Vessel1213 Vessel1213(提问者) 回复 Z4u3z1 没有主键这几个字段都是varchar类型,是一个很普通的表
    2023-02-14 14:54
  • Z4u3z1 Z4u3z1 回复 Vessel1213(提问者) SELECT * FROM ( SELECT [ryid] ,[ryxm] ,[dlsj] ,[tcsj],ROW_NUMBER() OVER(PARTITION BY ryid,ryxm,dlsj ORDER BY dlsj ASC,tcsj DESC) [I] FROM testS where [dlsj] between \'2023-02-03\' and \'2023-02-09\' --and dlsj ) T WHERE T.I=1 试试这个(斜杠是论坛自己加的 请删除)
    2023-02-14 15:03
  • Vessel1213 Vessel1213(提问者) 回复 Z4u3z1 取出来的结果不太对,有这样的数据 D001772 张一 2023-02-07 02:14:23 2023-02-07 08:38:16 1 D001772 张一 2023-02-07 03:14:40 2023-02-07 08:38:16 1
    2023-02-14 15:14
  • 286浏览人数
  • 最后回答于:2023-2-14 15:34
