如何修改参数?
以下是甲方旧报表的sql,他们是头部将finereport参数传给它,尾部直接调用数据库的参数,我要在sqlserver弄T+1再用KETTLE抽到MySQL中间库,最终是在帆软上调用这个mysql的中间库,难的是他们要求的时间维度有很多种,我应该怎么去改这个参数好呢?
declare @startTime datetime ,@endTime datetime
 select @startTime='${startTime}' ,@endTime='${endTime}'
--select @startTime = '2021-06-01', @endTime = '2021-06-10'
SELECT f.FarmID,
       f.FarmName as '猪场',
       f.FarmName+line.LineName as '生产线',
       ''         as '计划配种数',
       (select count(*)
        from ([Pigs].[T_Mating] as mating
                 LEFT JOIN V_PigsArchives AS arc
                           ON mating.PigsArchivesID = arc.PigsArchivesID
                 LEFT JOIN Farm.T_Houses AS house
                           ON house.HouseID = arc.HouseID)
        where mating.FirstMatingDate between @startTime and @endTime
          and house.ProductionLineID = line.ProductionLineID
       )          as '实际配种数',
       (select count(*)
        from ([Pigs].[T_PregnancyTest] as pre
                           ON pre.PigsArchivesID = arc.PigsArchivesID
        where pre.PregnancyTestDate between @startTime and @endTime
          and (pre.PregnancyTestResult = 2 or pre.PregnancyTestResult = 3)
       )          as '返情空怀',
          isnull((select count(*)
                 right join [Pigs].[T_Death] death on arc.PigsArchivesID = death.PigsArchivesID)
          and (death.DeathDate between @startTime and @endTime or arc.EliminatedDate between @startTime and @endTime)),0)
                  as '妊娠期淘汰数',
       (select count(*)
          and (pre.PregnancyTestResult = 4)
       )          as '流产'
(select count(*)
        from ([Pigs].[T_ChangeHouse] as change
                           ON change.PigsArchivesID = arc.PigsArchivesID
        where change.ChangeHouseDate between @startTime and @endTime
       )          as '场内调动'
FROM [Farm].[T_Farms] f
         right join [Farm].[T_ProductionLine] line
                    on f.FarmID = line.FarmID
where f.OrganID = 1 and f.IsDeleted=0 and f.FarmName!='虚拟公猪站'
${if(len(FarmID) == 0,""," and f.FarmID = '" + FarmID + "'")}
${if(len(ProductionLineID) == 0,""," and line.ProductionLineID = '" + ProductionLineID + "'")}
group by f.FarmID,f.FarmName, line.LineName, line.ProductionLineID
order by f.FarmID
FineReport 胡桂丹 发布于 2021-11-18 17:01
悬赏:5 F币 + 添加悬赏
杨朝健Lv5中级互助
发布于2021-11-18 17:36
把问题描述清楚一点
  • 胡桂丹 胡桂丹(提问者) 参数有日,周,月,季度,年,我要怎么改这个sql,才可以在帆软里面正常设置这些参数
    2021-11-18 17:50
  • 334浏览人数
  • 最后回答于:2021-11-18 17:36
