ApacheImpala数据连接报错,是什么原因?求哪位大神解决!!
java.sql.SQLException: [Simba][ImpalaJDBCDriver](500168) Error creating login context using ticket cache: Unable to obtain Principal Name for authentication . at com.cloudera.hivecommon.api.HiveServer2ClientFactory.createTransport(Unknown Source) at com.cloudera.hivecommon.api.HiveServer2ClientFactory.createClient(Unknown Source) at com.cloudera.hivecommon.core.HiveJDBCCommonConnection.connect(Unknown Source) at com.cloudera.jdbc.common.BaseConnectionFactory.doConnect(Unknown Source) at com.cloudera.jdbc.common.AbstractDriver.connect(Unknown Source) at com.fr.third.alibaba.druid.pool.DruidAbstractDataSource.createPhysicalConnection(DruidAbstractDataSource.java:1461) at com.fr.third.alibaba.druid.pool.DruidAbstractDataSource.createPhysicalConnection(DruidAbstractDataSource.java:1525) Caused by: com.cloudera.support.exceptions.GeneralException: [Simba][ImpalaJDBCDriver](500168) Error creating login context using ticket cache: Unable to obtain Principal Name for authentication . ... 7 more Caused by: javax.security.auth.login.LoginException: Unable to obtain Principal Name for authentication at jdk.security.auth/com.sun.security.auth.module.Krb5LoginModule.promptForName(Krb5LoginModule.java:819) at jdk.security.auth/com.sun.security.auth.module.Krb5LoginModule.attemptAuthentication(Krb5LoginModule.java:682) at jdk.security.auth/com.sun.security.auth.module.Krb5LoginModule.login(Krb5LoginModule.java:592) at java.base/javax.security.auth.login.LoginContext.invoke(LoginContext.java:726) at java.base/javax.security.auth.login.LoginContext$4.run(LoginContext.java:665) at java.base/javax.security.auth.login.LoginContext$4.run(LoginContext.java:663) at java.base/java.security.AccessController.doPrivileged(Native Method) at java.base/javax.security.auth.login.LoginContext.invokePriv(LoginContext.java:663) at java.base/javax.security.auth.login.LoginContext.login(LoginContext.java:574) at com.cloudera.jdbc.kerberos.Kerberos.getSubjectViaTicketCache(Unknown Source) at com.cloudera.hivecommon.api.HiveServer2ClientFactory.createTransport(Unknown Source) at com.cloudera.hivecommon.api.HiveServer2ClientFactory.createClient(Unknown Source) at com.cloudera.hivecommon.core.HiveJDBCCommonConnection.connect(Unknown Source) at com.cloudera.jdbc.common.BaseConnectionFactory.doConnect(Unknown Source) at com.cloudera.jdbc.common.AbstractDriver.connect(Unknown Source) at com.fr.third.alibaba.druid.pool.DruidAbstractDataSource.createPhysicalConnection(DruidAbstractDataSource.java:1461) at com.fr.third.alibaba.druid.pool.DruidAbstractDataSource.createPhysicalConnection(DruidAbstractDataSource.java:1525) at com.fr.third.alibaba.druid.pool.DruidDataSource$CreateConnectionThread.run(DruidDataSource.java:2165)
FineReport smy001 发布于 2021-11-23 14:04
发布于2021-11-23 14:11
Apache Impala数据连接-https://help.fanruan.com/finebi/doc-view-293.html
  • smy001 smy001(提问者) 老师,您好!我就是按照这个链接地址上的说明操作的,但是会报这样的错误。 java.sql.SQLException: [Simba][ImpalaJDBCDriver](500168) Error creating login context using ticket cache: Unable to obtain Principal Name for authentication . at com.cloudera.hivecommon.api.HiveServer2ClientFactory.createTransport(Unknown Source) at com.cloudera.hivecommon.api.HiveServer2ClientFactory.createClient(Unknown Source) at com.cloudera.hivecommon.core.HiveJDBCCommonConnection.connect(Unknown Source) at com.cloudera.jdbc.common.BaseConnectionFactory.doConnect(Unknown Source) at com.cloudera.jdbc.common.AbstractDriver.connect(Unknown Source) at com.fr.third.alibaba.druid.pool.DruidAbstractDataSource.createPhysicalConnection(DruidAbstractDataSource.java:1461) at com.fr.third.alibaba.druid.pool.DruidAbstractDataSource.createPhysicalConnection(DruidAbstractDataSource.java:1525) Caused by: com.cloudera.support.exceptions.GeneralException: [Simba][ImpalaJDBCDriver](500168) Error creating login context using ticket cache: Unable to obtain Principal Name for authentication . ... 7 more Caused by: javax.security.auth.login.LoginException: Unable to obtain Principal Name for authentication at jdk.security.auth/com.sun.security.auth.module.Krb5LoginModule.promptForName(Krb5LoginModule.java:819) at jdk.security.auth/com.sun.security.auth.module.Krb5LoginModule.attemptAuthentication(Krb5LoginModule.java:682) at jdk.security.auth/com.sun.security.auth.module.Krb5LoginModule.login(Krb5LoginModule.java:592) at java.base/javax.security.auth.login.LoginContext.invoke(LoginContext.java:726) at java.base/javax.security.auth.login.LoginContext$4.run(LoginContext.java:665) at java.base/javax.security.auth.login.LoginContext$4.run(LoginContext.java:663) at java.base/java.security.AccessController.doPrivileged(Native Method) at java.base/javax.security.auth.login.LoginContext.invokePriv(LoginContext.java:663) at java.base/javax.security.auth.login.LoginContext.login(LoginContext.java:574) at com.cloudera.jdbc.kerberos.Kerberos.getSubjectViaTicketCache(Unknown Source) at com.cloudera.hivecommon.api.HiveServer2ClientFactory.createTransport(Unknown Source) at com.cloudera.hivecommon.api.HiveServer2ClientFactory.createClient(Unknown Source) at com.cloudera.hivecommon.core.HiveJDBCCommonConnection.connect(Unknown Source) at com.cloudera.jdbc.common.BaseConnectionFactory.doConnect(Unknown Source) at com.cloudera.jdbc.common.AbstractDriver.connect(Unknown Source) at com.fr.third.alibaba.druid.pool.DruidAbstractDataSource.createPhysicalConnection(DruidAbstractDataSource.java:1461) at com.fr.third.alibaba.druid.pool.DruidAbstractDataSource.createPhysicalConnection(DruidAbstractDataSource.java:1525) at com.fr.third.alibaba.druid.pool.DruidDataSource$CreateConnectionThread.run(DruidDataSource.java:2165)
    2021-11-23 17:37
  • zsh331 zsh331 回复 smy001(提问者) 日志反映「无法获取主体名称,仔细对比下2.2部分介绍」
    2021-11-23 17:42
  • smy001 smy001(提问者) 回复 zsh331 老师,您好!仔细对比后出现这个错误。 java.sql.SQLException: [Simba][ImpalaJDBCDriver](500166) Error creating login context using JAAS configuration: Unable to obtain password from user . at com.cloudera.hivecommon.api.HiveServer2ClientFactory.createTransport(Unknown Source) at com.cloudera.hivecommon.api.HiveServer2ClientFactory.createClient(Unknown Source) at com.cloudera.hivecommon.core.HiveJDBCCommonConnection.connect(Unknown Source) at com.cloudera.jdbc.common.BaseConnectionFactory.doConnect(Unknown Source) at com.cloudera.jdbc.common.AbstractDriver.connect(Unknown Source) at com.fr.third.alibaba.druid.pool.DruidAbstractDataSource.createPhysicalConnection(DruidAbstractDataSource.java:1461) at com.fr.third.alibaba.druid.pool.DruidAbstractDataSource.createPhysicalConnection(DruidAbstractDataSource.java:1525) Caused by: com.cloudera.support.exceptions.GeneralException: [Simba][ImpalaJDBCDriver](500166) Error creating login context using JAAS configuration: Unable to obtain password from user . ... 7 more Caused by: javax.security.auth.login.LoginException: Unable to obtain password from user at jdk.security.auth/com.sun.security.auth.module.Krb5LoginModule.promptForPass(Krb5LoginModule.java:875) at jdk.security.auth/com.sun.security.auth.module.Krb5LoginModule.attemptAuthentication(Krb5LoginModule.java:738) at jdk.security.auth/com.sun.security.auth.module.Krb5LoginModule.login(Krb5LoginModule.java:592) at java.base/javax.security.auth.login.LoginContext.invoke(LoginContext.java:726) at java.base/javax.security.auth.login.LoginContext$4.run(LoginContext.java:665) at java.base/javax.security.auth.login.LoginContext$4.run(LoginContext.java:663) at java.base/java.security.AccessController.doPrivileged(Native Method) at java.base/javax.security.auth.login.LoginContext.invokePriv(LoginContext.java:663) at java.base/javax.security.auth.login.LoginContext.login(LoginContext.java:574) at com.cloudera.jdbc.kerberos.Kerberos.getSubjectViaJAASConfig(Unknown Source) at com.cloudera.hivecommon.api.HiveServer2ClientFactory.createTransport(Unknown Source) at com.cloudera.hivecommon.api.HiveServer2ClientFactory.createClient(Unknown Source) at com.cloudera.hivecommon.core.HiveJDBCCommonConnection.connect(Unknown Source) at com.cloudera.jdbc.common.BaseConnectionFactory.doConnect(Unknown Source) at com.cloudera.jdbc.common.AbstractDriver.connect(Unknown Source) at com.fr.third.alibaba.druid.pool.DruidAbstractDataSource.createPhysicalConnection(DruidAbstractDataSource.java:1461) at com.fr.third.alibaba.druid.pool.DruidAbstractDataSource.createPhysicalConnection(DruidAbstractDataSource.java:1525) at com.fr.third.alibaba.druid.pool.DruidDataSource$CreateConnectionThread.run(DruidDataSource.java:2165)
    2021-11-24 14:36
  • 1331浏览人数
  • 最后回答于:2021-11-23 14:11
