sql写法问题
${IF(pRESOURCE_TYPE = '现存已配车',"
select
calculation_method,
car_series,
car_model,
sum(allocation_predict_qty) as qty
from
dal.dal_dvmp_delivery_forecast_fr
where
 calculation_method in ('"+pd+"')
"group by car_series,calculation_method,
car_model
"select
car_series,
car_model,
from
car_model
,请问这个怎么嵌套参数为空选择全部
例如
${if(len(pMETHOD) == 0,"","and calculation_method  IN ('" +pMETHOD + "')")}
FineReport Leonard.Lin 发布于 2021-12-30 14:30
发布于2021-12-30 14:33(编辑于 2021-12-30 14:33)
select
calculation_method,
car_series,
car_model,
from
where 1=1 "
+if(len(pMETHOD) == 0,"","and calculation_method  IN ('" +pMETHOD + "')")+
car_model",
"select
car_series,
car_model,
from
car_model
  • Leonard.Lin Leonard.Lin(提问者) 如果在加一个${if(len(pPOINT) == 0,\"\",\"and car_contract_use_node IN (\'\" +pPOINT + \"\')\")},应该咋写!
    2021-12-30 14:37
  • Leonard.Lin Leonard.Lin(提问者) 直接复制之前的就可以了是吧
    2021-12-30 14:37
  • snrtuemc snrtuemc 回复 Leonard.Lin(提问者) 我给你加进去了啊,注意把${}去掉
    2021-12-30 14:38
  • 333浏览人数
  • 最后回答于:2021-12-30 14:33
