帆软报表中设置一个单选下拉框,我配置后总是提示错误代码11300001
帆软报表中设置一个单选下拉框,我配置后总是提示错误代码11300001,数据集配置错误,出现不支持的SQL标记,118。
下拉框名字为tongjikj ,自定义了两个值  tj1 和  tj2
sql中where 条件这样写的
${if(tongjikj == "tj1","  trunc(tongjirq) BETWEEN TO_DATE('${date_start}', 'YYYY-MM-DD') AND TO_DATE('${date_end}', 'YYYY-MM-DD')", "")}
${if(tongjikj == "tj2","  trunc(jisuanrq) BETWEEN TO_DATE('${date_start}', 'YYYY-MM-DD') AND TO_DATE('${date_end}', 'YYYY-MM-DD')", "")}
哪里错了呢
FineReport ZcyMrLTJ 发布于 2022-1-12 22:06
发布于2022-1-12 22:14
参考写法,根据需求灵活扩展;
select * from tabname where 1=1
${if(tongjikj == "tj1"," and   trunc(tongjirq) BETWEEN TO_DATE('"+date_start+"', 'YYYY-MM-DD') AND TO_DATE('"+date_end+"', 'YYYY-MM-DD')", "")}
${if(tongjikj == "tj2"," and   trunc(jisuanrq) BETWEEN TO_DATE('"+date_start+"', 'YYYY-MM-DD') AND TO_DATE('"+date_end+"', 'YYYY-MM-DD')", "")}
  • 288浏览人数
  • 最后回答于:2022-1-12 22:14
