最佳回答 |
axingLv6专家互助发布于2022-1-25 21:47
加一个参数就好了 window.open(FR.cjkEncode("${servletURL}?viewlet=water_envir/jcsj_tb.cpt&op=write&project_id="+project_id),"_self");
最佳回答 |
CD20160914Lv8专家互助发布于2022-1-25 17:24(编辑于 2022-1-25 19:56)
FR.doHyperlinkByPost({ "url":"${servletURL}?viewlet=water_envir/jcsj_tb.cpt&op=write", "para":{ "__pi__":true, //是否显示参数面板 "project_id":project_id,}, "target":"_dialog", //对话框方式打开 "feature":{ "width":800, //宽度 "height":400, //高度 "isCenter":false, //是否居中显示 "title":"报表"} }) 点击按钮里面写一个获取参数。。。如下 ![1643111806156487.png image.png](/upload/wenda/20220125/1643111806156487.png)
最佳回答 |
linbodingLv6中级互助发布于2022-1-25 17:24(编辑于 2022-1-25 17:25)
最佳回答 |
普普通通的lenLv3见习互助发布于2022-1-25 17:25
var $iframe = $("<iframe id='inp' name='inp' width='100%' height='100%' scrolling='no' frameborder='0'>"); // iframe参数的命名及宽高等
$iframe.attr("src", "http://localhost:8075/webroot/decision/view/form?viewlet=%25E6%258E%25A7%25E4%25BB%25B6%25E6%25B5%258B%25E8%25AF%2595.frm"); //childtest.cpt为点击查询时,对话框中显示的子报表
var o = {
title: "标题",
width: 300, //调整对话框宽度
height: 180 //调整对话框高度
FR.showDialog(o.title, o.width, o.height, $iframe, o); //弹出对话框
最佳回答 |
LTC朝Lv6高级互助发布于2022-1-25 17:25(编辑于 2022-1-25 17:26)
![1643102788847080.png image.png](/upload/wenda/20220125/1643102788847080.png)
window.location="/WebReport/ReportServer?formlet=%5B586b%5D%5B62a5%5D%5B62a5%5D%5B8868%5D%2F%5B8d39%5D%5B7528%5D%5B586b%5D%5B62a5%5D%2F%5B8d39%5D%5B7528%5D%5B586b%5D%5B62a5%5D%5B9996%5D%5B9875%5D.frm"; formlet=后面见截图 ![1643102722917902.png image.png](/upload/wenda/20220125/1643102722917902.png)
最佳回答 |
飞段Lv6初级互助发布于2022-1-26 11:22
var $iframe = $("<iframe id='inp' name='inp' width='100%' height='100%' scrolling='no' frameborder='0'>"); $iframe.attr("src", "${servletURL}?reportlet=yq contract/yq_contract_insert.cpt&op=write"); var o = { title : "需求新增", width : 1000, height: 500 }; FR.showDialog(o.title, o.width, o.height, $iframe,o);
