mysql怎么获取一个月里面有几个星期一哈?
yikefu 发布于 2022-3-7 16:42
发布于2022-3-7 16:47(编辑于 2022-3-7 16:56)
select sum(case when date_format(t.day,'%w') =1 then 1 else 0 end ) as 星期一个数 from (
select date_add('2022-01-01', interval (cast(help_topic_id as signed integer)) day) day
from mysql.help_topic
where help_topic_id < datediff('2022-01-31', '2022-01-01') + 1
order by help_topic_id) t
----------另一种写法------------
select sum(case when dayofweek(t.day)-1 =1 then 1 else 0 end ) as 星期一个数 from (
用户W4933403Lv5初级互助
发布于2022-3-7 17:15
set @ym ='2022-03';
select DAY(LAST_DAY(concat(@ym,'-01'))) div 7 +
(DAY(LAST_DAY(concat(@ym,'-01'))) % 7 + (case (DAYOFWEEK(concat(@ym,'-01'))-1) when 0 then 7 else (DAYOFWEEK(concat(@ym,'-01'))-1) end) ) div 7
  • 364浏览人数
  • 最后回答于:2022-3-7 17:15
