帆软能实现这个以下问题的逻辑么,有点长
比如我选择第一季度的时候,单元格根据现在的月份去求和,例如,现在三月份,选择第一季度时一二月份求和,如果实际月份是四月份,就一二三月求和,如果是一月份就一月求和,图里的数据是去年的,是需要扣当前年的image.png能够实现么,业务部门提出的需求我实在是想不出来了QAQ
FineReport 猴不是猴 发布于 2022-3-9 11:14 (编辑于 2022-3-9 11:26)
发布于2022-3-9 11:18(编辑于 2022-3-9 12:46)
为什么3月份的不能求和???
----------------------------------以下是mysql测试的语句-------------------------
select t2.* from (
select t.month_s,t.year_code,t.number_s from (
select '1' as month_s,'2021' as year_code,38 as number_s union all
select '2' as month_s,'2021' as year_code,356 as number_s union all
select '3' as month_s,'2021' as year_code,493 as number_s union all
select '4' as month_s,'2021' as year_code,115 as number_s union all
select '5' as month_s,'2021' as year_code,565 as number_s union all
select '6' as month_s,'2021' as year_code,565 as number_s union all
select '7' as month_s,'2021' as year_code,341 as number_s union all
select '8' as month_s,'2021' as year_code,393 as number_s union all
select '9' as month_s,'2021' as year_code,582 as number_s union all
select '10' as month_s,'2021' as year_code,28 as number_s union all
select '11' as month_s,'2021' as year_code,689 as number_s union all
select '12' as month_s,'2021' as year_code,452 as number_s union all
select '1' as month_s,'2022' as year_code,396 as number_s union all
select '2' as month_s,'2022' as year_code,352 as number_s union all
select '3' as month_s,'2022' as year_code,331 as number_s union all
select '4' as month_s,'2022' as year_code,563 as number_s union all
select '5' as month_s,'2022' as year_code,160 as number_s
) t
where 1=1
/*取年*/
${if(len(year_code)=0,"","and t.year_code= '"+ year_code + "'")}
/*历史年的直接查询季度对应的数据,如果i不是历史年的数据,先按季度把每三个月的数据查询出来*/
${if(year_code<year(today())&& jd =1 ," and t.month_s in('1','2','3')",if(year_code<year(today())&& jd =2 ," and t.month_s in('4','5','6')",if(year_code<year(today())&& jd =3 ," and t.month_s in('7','8','9')",if(year_code<year(today())&& jd =4 ," and t.month_s in('10','11','12')",if(year_code=year(today()) && jd =1 ," and t.month_s in('1','2','3')",if(year_code=year(today()) && jd =2 ," and t.month_s in('4','5','6')",if(year_code=year(today()) && jd =3 ," and t.month_s in('7','8','9')"," and t.month_s in('10','11','12')")))))))}
) t2
where 1=1
and t2.month_s<'${month(today())}'  /*最后再判断一次月份小于当前服务器的月份就行了*/
/*2022年1季度的sql限制*/
  • 猴不是猴 猴不是猴(提问者) 因为他们还要除一个人均,三月份没过完整个三月数据不全会印象平均值QAQ
    2022-03-09 11:21
  • CD20160914 CD20160914 回复 猴不是猴(提问者) 那直接写在where的条件判断中吧。但是如果现在是2022-01-10号,月份还没有过完。人家选择了1季度,,不就是不求和了?
    2022-03-09 11:24
  • 猴不是猴 猴不是猴(提问者) 回复 CD20160914 最搞的就是 一月份当月的话他们需要一月求和,我就麻了
    2022-03-09 11:27
  • CD20160914 CD20160914 回复 猴不是猴(提问者) 上面改了。为了显得不那么复杂。我套了两次查询。这样容易理解一些。不然全在一个if里面判断太复杂。看类似的语句,你改成你的表名。与字段就行了。。我是mysql测试的。
    2022-03-09 12:42
linbodingLv6中级互助
发布于2022-3-9 11:17(编辑于 2022-3-9 11:21)
用sql判断啊,如果是第一季度,数据就=01,02,03月份啊,顺推就好了
where case when '${参数}' = 'q1'
     then  when right(日期,2) in ('01','02','03')
                 then  year(日期)=year('${时间参数}')
     when    .....
     end
  • 猴不是猴 猴不是猴(提问者) 主要是 如果是现在是一月份 一月数据汇总 但到了二月份 二月还没结束 他需要的还是一月的汇总,如果到了四月份,他需要的是一二三月的汇总,这个我就绕不出来了 不知道怎么解决了
    2022-03-09 11:20
  • linboding linboding 回复 猴不是猴(提问者) 那先做一次时间上的过滤,比如先过滤时间,数据要小于当前月份,就不会把二月份的数据算上了
    2022-03-09 11:24
发布于2022-3-9 11:24(编辑于 2022-3-9 13:08)
他们的需求没描述清楚还是你没描述清楚?
扣除当月的数据这个应该是当年份
是当年的情况才扣除吧?以前的不需要扣吧??
WorkBook1.zip
  • 猴不是猴 猴不是猴(提问者) 对对对 这个忘记说了
    2022-03-09 11:26
  • Z4u3z1 Z4u3z1 回复 猴不是猴(提问者) 下载demo.SQL 语句直接用 WHERE 日期字段>=\'${RQ1_}\' and 日期字段<\'${RQ2_}\'
    2022-03-09 13:09
yzm339714Lv6中级互助
发布于2022-3-9 11:25
sql 加判断处理呗,
where year = ${year}
${if(jd = 1," and month in (1,2,3)   "," ")}
${if(jd = 2," and month in (4,5,6)  "," ")}
${if(jd = 3," and month in (7,8,9) "," ")}
如果只有一个时间字段的话,就要麻烦了。用存储过程去处理把,存储过程里面拼接新的时间
  • 421浏览人数
  • 最后回答于:2022-3-9 13:08
