linux安装fineBI后无法启动
22:34:18 ParallelStrategy-4-worker-2 INFO [standard] Module DefaultLogActivator started.Time used 129 ms.22:34:18 ParallelStrategy-4-worker-2 INFO [standard] Module ClassFactoryActivator starting...22:34:18 ParallelStrategy-4-worker-2 INFO [standard] Module ClassFactoryActivator started.Time used 0 ms.22:34:18 ParallelStrategy-4-worker-2 INFO [standard] Module SerializationActivator starting...22:34:18 ParallelStrategy-4-worker-2 INFO [standard] Module SerializationActivator started.Time used 7 ms.22:34:18 ParallelStrategy-4-worker-2 INFO [standard] Module JsonSerializationActivator starting...22:34:18 ParallelStrategy-4-worker-2 INFO [standard] Module JsonSerializationActivator started.Time used 249 ms.22:34:18 ParallelStrategy-4-worker-2 INFO [standard] Module WorkspaceActivator starting...22:34:18 ParallelStrategy-4-worker-2 INFO [standard] Module WorkspaceRegister starting...22:34:18 ParallelStrategy-4-worker-2 INFO [standard] Module WorkspaceRegister started.Time used 0 ms.22:34:18 ParallelStrategy-4-worker-2 INFO [standard] Module WorkspaceActivator started.Time used 12 ms.22:34:18 ParallelStrategy-4-worker-2 INFO [standard] Module XMLableActivator starting...22:34:18 ParallelStrategy-4-worker-2 INFO [standard] Module XMLableActivator started.Time used 1 ms.22:34:18 ParallelStrategy-4-worker-2 INFO [standard] Module VirtualActivator started.Time used 598 ms.22:34:18 localhost-startStop-1 INFO [standard] Module VirtualActivator started.Time used 645 ms.22:34:18 localhost-startStop-1 INFO [standard] Module VirtualActivator started.Time used 1070 ms.22:34:18 localhost-startStop-1 INFO [standard] Module ServerWorkspaceProvider starting...22:34:18 localhost-startStop-1 INFO [standard] Module ServerWorkspaceProvider started.Time used 24 ms.22:34:18 localhost-startStop-1 INFO [standard] Module CoreActivator starting...22:34:18 localhost-startStop-1 INFO [standard] Module SecuritySeedsActivator starting...22:34:18 localhost-startStop-1 INFO [standard] seed file: default_alpha doesn't exist or empty22:34:18 localhost-startStop-1 INFO [standard] seed file: default_alpha doesn't exist or empty22:34:18 localhost-startStop-1 INFO [standard] Module SecuritySeedsActivator started.Time used 17 ms.22:34:18 localhost-startStop-1 INFO [standard] Module BaseDBActivator starting...22:34:19 BaseDBActivator-5-worker-1 INFO [com.fr.third.alibaba.druid.pool.DruidDataSource] testOnBorrow is true, validationQuery not set22:34:19 BaseDBActivator-5-worker-1 INFO [com.fr.third.alibaba.druid.pool.DruidDataSource] {dataSource-1} inited22:34:22 localhost-startStop-1 INFO [standard] Module BaseDBActivator started.Time used 3496 ms.22:34:22 localhost-startStop-1 INFO [standard] Module TenantDBAdapter starting...22:34:22 localhost-startStop-1 INFO [standard] Module TenantDBAdapter started.Time used 115 ms.22:34:22 localhost-startStop-1 INFO [standard] Module ConfigurationActivator starting...22:34:22 localhost-startStop-1 INFO [standard] cache invalidate com.fr.security.SecurityConfig22:34:22 localhost-startStop-1 INFO [standard] Module ConfigurationActivator started.Time used 786 ms.22:34:22 localhost-startStop-1 INFO [standard] Module VirtualActivator starting...22:34:22 localhost-startStop-1 INFO [standard] Module FineLoggerActivator starting...22:34:22 localhost-startStop-1 INFO [standard]  Module FineLoggerActivator started.Time used 10 ms.22:34:22 localhost-startStop-1 INFO [standard]  Module VirtualActivator started.Time used 11 ms.22:34:22 localhost-startStop-1 INFO [standard]  Module PluginActivator starting...22:34:29 FinePluginController-6-worker-1 INFO [standard]  cache invalidate com.fr.io.base.ResourcePathConfig22:34:29 FinePluginController-6-worker-1 INFO [standard]  cache invalidate com.fr.io.base.ResourcePathConfig22:34:29 FinePluginController-6-worker-1 WARN [standard]  [Cluster] GlobalMCastAddress is not matched: [224.0.1.46] from database, but [224.0.1.89] from this node!22:34:29 FinePluginController-6-worker-1 INFO [standard]  cache invalidate com.fr.cluster.engine.base.FineClusterConfig22:34:29 FinePluginController-6-worker-1 WARN [standard]  [Cluster] LocalMCastAddress is not matched: [237.74.7.31] from database, but [230.195.90.37] from this node!22:34:29 FinePluginController-6-worker-1 INFO [standard]  cache invalidate com.fr.cluster.engine.base.FineClusterConfig22:34:29 FinePluginController-6-worker-1 INFO [standard]  cache invalidate com.fr.cluster.engine.base.FineClusterConfig22:34:29 FinePluginController-6-worker-1 INFO [standard]  cache invalidate com.fr.cluster.engine.base.FineClusterConfig22:34:29 FinePluginController-6-worker-1 INFO [standard]  cache invalidate com.fr.cluster.engine.base.FineClusterConfig22:34:29 FinePluginController-6-worker-1 INFO [standard]  cache invalidate com.fr.cluster.engine.base.FineClusterConfig22:34:30 FinePluginController-6-worker-1 ERROR [standard]  Dynamic transform error:com.finebi.plugin.bi.info.log.appender.MyDailyRollingFileAppender22:34:30 CloudCenter-7-worker-1 INFO [standard]  Load cloud config spend time 1588 ms22:34:30 FinePluginController-6-worker-1 ERROR [standard]  Dynamic transform error:com.finebi.plugin.bi.info.log.PluginLogSettingHandler22:34:30 FinePluginController-6-worker-1 INFO [standard]  [plugin-bi-info-log]set log level: INFO22:34:30 FinePluginController-6-worker-1 INFO [standard]  cache invalidate com.fr.general.log.Log4jConfig22:34:30 FinePluginController-6-worker-1 INFO [standard]  [plugin-bi-info-log]set log stackDepth: -122:34:31 localhost-startStop-1 INFO [standard]  Plugin engine is started.22:34:31 localhost-startStop-1 INFO [standard]  Module PluginDBActivator starting...22:34:31 localhost-startStop-1 INFO [com.fr.third.alibaba.druid.pool.DruidDataSource]  testOnBorrow is true, validationQuery not set22:34:31 localhost-startStop-1 INFO [com.fr.third.alibaba.druid.pool.DruidDataSource]  {dataSource-2} inited22:34:31 localhost-startStop-1 INFO [standard]  Module PluginDBActivator started.Time used 271 ms.22:34:31 localhost-startStop-1 INFO [standard]  Module PluginInjectionFilterRegister starting...22:34:31 localhost-startStop-1 INFO [standard]  Module PluginInjectionFilterRegister started.Time used 0 ms.22:34:31 localhost-startStop-1 INFO [standard]  Module PluginActivator started.Time used 8512 ms.22:34:31 localhost-startStop-1 INFO [standard]  Module BasicUpdateActivator starting...22:34:31 localhost-startStop-1 INFO [standard]  start unzip file:/media/longer/B2F4070FF406D58F/FineBI5.1/webapps/webroot/WEB-INF/assist/update/update.zip22:34:31 localhost-startStop-1 INFO [standard]  unzip file:/media/longer/B2F4070FF406D58F/FineBI5.1/webapps/webroot/WEB-INF/assist/update/update.zip finished22:34:32 localhost-startStop-1 INFO [standard]  start unzip file:/media/longer/B2F4070FF406D58F/FineBI5.1/webapps/webroot/WEB-INF/assist/update/update.zip22:34:33 localhost-startStop-1 INFO [standard]  unzip file:/media/longer/B2F4070FF406D58F/FineBI5.1/webapps/webroot/WEB-INF/assist/update/update.zip finished22:34:33 localhost-startStop-1 INFO [standard]  Module BasicUpdateActivator started.Time used 1594 ms.22:34:33 localhost-startStop-1 INFO [standard]  Module CoreActivator started.Time used 14541 ms.22:34:33 localhost-startStop-1 INFO [standard]  Module DatasourceActivator starting...22:34:33 localhost-startStop-1 INFO [standard]  Module DatasourceActivator started.Time used 0 ms.22:34:33 localhost-startStop-1 INFO [standard]  Module VirtualActivator starting...22:34:33 localhost-startStop-1 INFO [standard]  Module ChartBaseActivator starting...22:34:33 localhost-startStop-1 INFO [standard]  Module com.fr.chart.module.ChartModule is started.22:34:33 localhost-startStop-1 INFO [standard]  Module ChartBaseActivator started.Time used 389 ms.22:34:33 localhost-startStop-1 INFO [standard]  Module ReportBaseActivator starting...22:34:34 localhost-startStop-1 INFO [standard]  Module com.fr.form.module.FormModule is started.22:34:36 localhost-startStop-1 INFO [standard]  Module com.fr.page.module.PageModule is started.22:34:36 localhost-startStop-1 INFO [standard]  Module com.fr.view.module.ViewModule is started.22:34:36 localhost-startStop-1 INFO [standard]  Module com.fr.write.module.WriteModule is started.22:34:36 localhost-startStop-1 INFO [standard]  Module com.fr.report.enhancement.engine.write.module.WriteEnhanceModule is started.22:34:36 localhost-startStop-1 INFO [standard]  Module com.fr.report.module.EngineModule is started.22:34:37 localhost-startStop-1 INFO [standard]  Module VcsFolderManagerActivator starting...22:34:37 localhost-startStop-1 INFO [standard]  Module VcsFolderManagerActivator started.Time used 18 ms.22:34:37 localhost-startStop-1 INFO [standard]  Module ReportBaseActivator started.Time used 3604 ms.22:34:37 localhost-startStop-1 INFO [standard]  Module RestrictionActivator starting...22:34:37 localhost-startStop-1 INFO [standard]  Module RestrictionActivator started.Time used 51 ms.22:34:37 localhost-startStop-1 INFO [standard]  Module FormBaseActivator starting...22:34:37 localhost-startStop-1 INFO [standard]  Module FormBaseActivator started.Time used 4 ms.22:34:37 localhost-startStop-1 INFO [standard]  Module VirtualActivator started.Time used 4056 ms.22:34:37 localhost-startStop-1 INFO [standard]  Module ServerBasicActivator started.Time used 19699 ms.22:34:37 localhost-startStop-1 INFO [standard]  Module ServerActivator starting...22:34:37 localhost-startStop-1 INFO [standard]  Module VirtualActivator starting...22:34:37 localhost-startStop-1 INFO [standard]  Module ModuleHealActivator starting...22:34:37 localhost-startStop-1 INFO [standard]  Module ModuleHealActivator started.Time used 14 ms.22:34:37 localhost-startStop-1 INFO [standard]  Module BaseResourceActivator starting...22:34:37 localhost-startStop-1 INFO [standard]  Module BaseResourceActivator started.Time used 44 ms.22:34:37 localhost-startStop-1 INFO [standard]  Module StateServiceActivator starting...22:34:37 localhost-startStop-1 INFO [standard]  [StateService] Register memory component type:standalone.22:34:37 localhost-startStop-1 INFO [standard]  [StateService] Register memory component type:redis.22:34:37 localhost-startStop-1 INFO [standard]  [StateService] Register memory component type:redis_cluster.22:34:37 localhost-startStop-1 INFO [standard]  [StateService] Register memory component type:redis_sentinel.22:34:37 localhost-startStop-1 INFO [standard]  [StateService] state service refresh success22:34:37 localhost-startStop-1 INFO [standard]  [StateService] StateHubManager reset22:34:37 localhost-startStop-1 INFO [standard]  [StateService] FineCollectionClient before changing env.22:34:37 localhost-startStop-1 INFO [standard]  [StateService] FineCollectionClient start update collection objects.22:34:37 localhost-startStop-1 INFO [standard]  [StateService] FineCollectionClient finish update collection objects, spend 2 ms22:34:37 localhost-startStop-1 INFO [standard]  [StateService] FineCollectionClient after changing env.22:34:37 localhost-startStop-1 INFO [standard]  cache invalidate com.fr.store.StateServerPluginConfig22:34:37 localhost-startStop-1 INFO [standard]  start loop detector: STATE_SERVICE_MODULE22:34:37 localhost-startStop-1 INFO [standard]  Module StateServiceActivator started.Time used 343 ms.22:34:37 localhost-startStop-1 INFO [standard]  Module ClusterModule starting...22:34:37 localhost-startStop-1 INFO [standard]  Module ClusterPrepare starting...22:34:37 localhost-startStop-1 INFO [standard]  Module VirtualActivator starting...22:34:37 localhost-startStop-1 INFO [standard]  Module VirtualActivator started.Time used 0 ms.22:34:37 localhost-startStop-1 INFO [standard]  Module ClusterPrepare started.Time used 1 ms.22:34:37 localhost-startStop-1 INFO [standard]  Module StandaloneModeActivator starting...22:34:37 localhost-startStop-1 INFO [standard]  提示代码:12400001 使用dmidecode -t 1获取机器信息来验证是否注册22:34:37 localhost-startStop-1 INFO [standard]  Module StandaloneModeActivator started.Time used 180 ms.22:34:38 localhost-startStop-1 INFO [standard]  Module ClusterModule started.Time used 898 ms.22:34:38 localhost-startStop-1 INFO [standard]  Module JGroupsClusterCacheActivator starting...22:34:38 localhost-startStop-1 INFO [standard]  [Cluster] MachineMarker config node id is null. Start to random UUID!22:34:38 localhost-startStop-1 INFO [standard]  [Cluster] MachineMarker get node id 8b504e4b-1b28-d1de-a94c-52fca60ba4e522:34:38 localhost-startStop-1 INFO [standard]  [Cluster] MachineMarker create backup node id aaf25fd4-ee7b-5e78-81db-612068d5b4de22:34:38 localhost-startStop-1 INFO [standard]  Module JGroupsClusterCacheActivator started.Time used 122 ms.22:34:38 localhost-startStop-1 INFO [standard]  Module ConfigRpcActivator starting...22:34:38 localhost-startStop-1 INFO [standard]  Module ConfigRpcActivator started.Time used 0 ms.22:34:38 localhost-startStop-1 INFO [standard]  Module ResourceRepositoryActivator starting...22:34:38 localhost-startStop-1 INFO [standard]  [Resource] Init resource repository backup strategy WARN_ONLY.22:34:38 localhost-startStop-1 INFO [standard]  [Resource] Repository factory: FileSystem is added!22:34:38 localhost-startStop-1 INFO [standard]  [Resource] Repository factory: FTP is added!22:34:38 localhost-startStop-1 INFO [standard]  cache invalidate com.fr.io.config.ResourceModuleConfig22:34:38 localhost-startStop-1 INFO [standard]  cache invalidate com.fr.io.config.ResourceModuleConfig22:34:38 localhost-startStop-1 INFO [standard]  [Resource] Repository switch from  to LOCAL_ENV success!22:34:38 localhost-startStop-1 INFO [standard]  cache invalidate com.fr.io.config.ResourceModuleConfig22:34:38 localhost-startStop-1 INFO [standard]  cache invalidate com.fr.io.base.ResourcePathConfig22:34:38 localhost-startStop-1 INFO [standard]  cache invalidate com.fr.io.base.ResourcePathConfig22:34:38 localhost-startStop-1 INFO [standard]  cache invalidate com.fr.io.base.ResourcePathConfig22:34:38 localhost-startStop-1 INFO [standard]  [plugin-bi-info-log][SwallowDunplicate] log message dunplicate for 5 times, message: cache invalidate com.fr.io.base.ResourcePathConfig22:34:38 localhost-startStop-1 INFO [standard]  [Resource] Resource module is started!22:34:38 localhost-startStop-1 INFO [standard]  Module ResourceSyncActivator starting...22:34:38 localhost-startStop-1 INFO [standard]  Module ResourceSyncActivator started.Time used 13 ms.22:34:38 localhost-startStop-1 INFO [standard]  Module ResourceRepositoryActivator started.Time used 138 ms.22:34:38 localhost-startStop-1 INFO [standard]  Module LicenseActivator starting...22:34:40 FinePluginController-6-worker-1 ERROR [standard]  Dynamic transform error:com.fr.plugin.performance.dzstartemptyfile.DesignerStartWithEmptyFile22:34:44 FinePluginController-6-worker-1 INFO [standard]  start unzip file:/media/longer/B2F4070FF406D58F/FineBI5.1/webapps/webroot/WEB-INF/plugins/installation_zips/plugin-com.fr.plugin.cloud.analytics.v10-2.2.0.20210728/plugin_installation.zip22:34:44 FinePluginController-6-worker-1 INFO [standard]  unzip file:/media/longer/B2F4070FF406D58F/FineBI5.1/webapps/webroot/WEB-INF/plugins/installation_zips/plugin-com.fr.plugin.cloud.analytics.v10-2.2.0.20210728/plugin_installation.zip finished22:34:50 FinePluginController-6-worker-1 INFO [com.fr.third.alibaba.druid.pool.DruidDataSource]  {dataSource-2} closed22:34:50 FinePluginController-6-worker-1 INFO [standard]  [StateService] UnRegister memory component type:redis_sentinel.22:34:53 localhost-startStop-1 INFO [standard]  Plugin engine is stopped.22:34:56 FinePluginController-6-worker-1 INFO [standard]  [StateService] Register memory component type:redis_sentinel.22:34:56 FinePluginController-6-worker-1 INFO [standard]  [StateService] state service refresh success22:34:56 FinePluginController-6-worker-1 INFO [standard]  [StateService] StateHubManager reset22:34:56 FinePluginController-6-worker-1 INFO [standard]  [StateService] FineCollectionClient before changing env.22:34:56 FinePluginController-6-worker-1 INFO [standard]  [StateService] FineCollectionClient start update collection objects.22:34:56 FinePluginController-6-worker-1 INFO [standard]  [StateService] FineCollectionClient finish update collection objects, spend 26 ms22:34:56 FinePluginController-6-worker-1 INFO [standard]  [StateService] FineCollectionClient after changing env.22:34:56 FinePluginController-6-worker-1 INFO [standard]  cache invalidate com.fr.store.StateServerPluginConfig22:34:57 FinePluginController-6-worker-1 INFO [com.fr.third.alibaba.druid.pool.DruidDataSource]  testOnBorrow is true, validationQuery not set22:34:57 FinePluginController-6-worker-1 INFO [com.fr.third.alibaba.druid.pool.DruidDataSource]  {dataSource-3} inited22:34:59 FinePluginController-6-worker-1 INFO [standard]  cache invalidate com.fr.io.base.ResourcePathConfig22:34:59 FinePluginController-6-worker-1 ERROR [standard]  Dynamic transform error:com.finebi.plugin.bi.info.log.appender.MyDailyRollingFileAppender22:34:59 FinePluginController-6-worker-1 ERROR [standard]  Dynamic transform error:com.finebi.plugin.bi.info.log.PluginLogSettingHandler22:34:59 FinePluginController-6-worker-1 INFO [standard]  [plugin-bi-info-log]set log level: INFO22:34:59 FinePluginController-6-worker-1 INFO [standard]  cache invalidate com.fr.general.log.Log4jConfig22:34:59 localhost-startStop-1 INFO [standard]  Plugin engine is started.22:34:59 localhost-startStop-1 INFO [standard]  Module LicenseActivator started.Time used 21199 ms.22:34:59 localhost-startStop-1 INFO [standard]  Module SchedulerActivator starting...22:34:59 localhost-startStop-1 INFO [standard]  DialectProvider:com.fr.data.core.db.dialect.DialectProviderImpl registered22:35:00 localhost-startStop-1 INFO [standard]  This quartz is in standalone mode.22:35:00 localhost-startStop-1 INFO [com.fr.third.alibaba.druid.pool.DruidDataSource]  testOnBorrow is true, testWhileIdle is true, validationQuery not set22:35:00 localhost-startStop-1 INFO [com.fr.third.alibaba.druid.pool.DruidDataSource]  {dataSource-4} inited22:35:01 FinePluginController-6-worker-1 ERROR [standard]  Dynamic transform error:com.fr.plugin.performance.dzstartemptyfile.DesignerStartWithEmptyFile22:35:02 localhost-startStop-1 INFO [standard]  Scheduler has been started.22:35:02 localhost-startStop-1 INFO [standard]  Job CloudAnalyticsCollector.authorityAssign removed.22:35:02 localhost-startStop-1 INFO [standard]  Job CloudAnalyticsCollector.confEntity removed.22:35:02 localhost-startStop-1 INFO [standard]  Job CloudAnalyticsCollector.containerMessage removed.22:35:03 localhost-startStop-1 INFO [standard]  Job CloudAnalyticsCollector.customerMessage removed.22:35:03 localhost-startStop-1 INFO [standard]  Job CloudAnalyticsCollector.dataSetUsage removed.22:35:03 localhost-startStop-1 INFO [standard]  Job CloudAnalyticsCollector.functionPossess removed.22:35:03 localhost-startStop-1 INFO [standard]  Job CloudAnalyticsCollector.pluginUsage removed.22:35:04 localhost-startStop-1 INFO [standard]  Job CloudAnalyticsCollector.realTime removed.22:35:04 localhost-startStop-1 INFO [standard]  Job CloudAnalyticsCollector.userManagement removed.22:35:04 localhost-startStop-1 INFO [standard]  Job CloudAnalyticsCollector.clusterConf removed.22:35:05 localhost-startStop-1 INFO [standard]  Job CloudAnalyticsCollector.connection removed.22:35:05 localhost-startStop-1 INFO [standard]  Job CloudAnalyticsCollector.directoryUsage removed.22:35:05 localhost-startStop-1 INFO [standard]  Job CloudAnalyticsCollector.scheduleUsage removed.22:35:05 localhost-startStop-1 INFO [standard]  Job CloudAnalyticsCollector.tplInfo removed.22:35:06 localhost-startStop-1 INFO [standard]  Job CloudAnalyticsCollector.workflowUsage removed.22:35:06 localhost-startStop-1 INFO [standard]  Job CloudAnalyticsCollector.BIFunctionPossess removed.22:35:06 localhost-startStop-1 INFO [standard]  Job CloudAnalyticsCollector.BIUserUsage removed.22:35:07 localhost-startStop-1 INFO [standard]  Job CloudAnalyticsCollector.BIScheduleUsage removed.22:35:07 localhost-startStop-1 INFO [standard]  Job CloudAnalyticsCollector.BIDirectoryUsage removed.22:35:07 localhost-startStop-1 INFO [standard]  Job CloudAnalytics.treasureClean removed.22:35:08 localhost-startStop-1 INFO [standard]  Job CloudAnalytics.treasureExport removed.22:35:08 localhost-startStop-1 INFO [standard]  Job CloudAnalytics.treasureUpload removed.22:35:08 localhost-startStop-1 INFO [standard]  Job CloudAnalytics.treasureUploadCheck removed.22:35:08 localhost-startStop-1 INFO [standard]  Job CloudAnalytics.systemRemind removed.22:35:08 localhost-startStop-1 INFO [standard]  Job CloudAnalytics.pluginDetect removed.22:35:08 localhost-startStop-1 INFO [standard]  Job SolidAnalytics.solidExport removed.22:35:08 localhost-startStop-1 INFO [standard]  Job SolidAnalytics.solidExportCheck removed.22:35:08 localhost-startStop-1 INFO [standard]  Job CloudAnalyticsCollector.appearanceConfig removed.22:35:08 localhost-startStop-1 INFO [standard]  Job CloudAnalyticsCollector.foreignPhone removed.22:35:08 localhost-startStop-1 INFO [standard]  Job CloudAnalyticsCollector.sqlFrequency removed.22:35:08 localhost-startStop-1 INFO [standard]  Job CloudAnalyticsCollector.BITableSumCollectTask removed.22:35:08 localhost-startStop-1 INFO [standard]  ADD JOB: treasureClean22:35:08 localhost-startStop-1 INFO [standard]  ADD JOB: treasureExport22:35:08 localhost-startStop-1 INFO [standard]  ADD JOB: treasureUpload22:35:08 localhost-startStop-1 INFO [standard]  ADD JOB: treasureUploadCheck22:35:08 localhost-startStop-1 INFO [standard]  ADD JOB: systemRemind22:35:08 localhost-startStop-1 INFO [standard]  ADD JOB: pluginDetect22:35:09 localhost-startStop-1 INFO [standard]  ADD JOB: solidExport22:35:09 localhost-startStop-1 INFO [standard]  ADD JOB: solidExportCheck22:35:09 localhost-startStop-1 INFO [standard]  ADD JOB: authorityAssign22:35:09 localhost-startStop-1 INFO [standard]  ADD JOB: confEntity22:35:09 localhost-startStop-1 INFO [standard]  ADD JOB: containerMessage22:35:09 localhost-startStop-1 INFO [standard]  ADD JOB: customerMessage22:35:09 localhost-startStop-1 INFO [standard]  ADD JOB: dataSetUsage22:35:09 localhost-startStop-1 INFO [standard]  ADD JOB: functionPossess22:35:09 localhost-startStop-1 INFO [standard]  ADD JOB: pluginUsage22:35:09 localhost-startStop-1 INFO [standard]  ADD JOB: realTime22:35:09 localhost-startStop-1 INFO [standard]  ADD JOB: userManagement22:35:09 localhost-startStop-1 INFO [standard]  ADD JOB: clusterConf22:35:09 localhost-startStop-1 INFO [standard]  ADD JOB: connection22:35:09 localhost-startStop-1 INFO [standard]  ADD JOB: directoryUsage22:35:09 localhost-startStop-1 INFO [standard]  ADD JOB: scheduleUsage22:35:09 localhost-startStop-1 INFO [standard]  ADD JOB: tplInfo22:35:09 localhost-startStop-1 INFO [standard]  ADD JOB: workflowUsage22:35:09 localhost-startStop-1 INFO [standard]  ADD JOB: BIFunctionPossess22:35:09 localhost-startStop-1 INFO [standard]  ADD JOB: BIUserUsage22:35:09 localhost-startStop-1 INFO [standard]  ADD JOB: BIScheduleUsage22:35:09 localhost-startStop-1 INFO [standard]  ADD JOB: BIDirectoryUsage22:35:09 QuartzScheduler_Worker-3 ERROR [standard]  java.lang.NullPointerException    at com.fr.schedule.feature.job.usage.ScheduleUsageDataJob.run(Unknown Source)    at com.fr.scheduler.job.FineScheduleJob.execute(FineScheduleJob.java:31)    at com.fr.third.v2.org.quartz.core.JobRunShell.run(JobRunShell.java:203)    at com.fr.third.alibaba.ttl.TtlRunnable.run(TtlRunnable.java:58)    at com.fr.third.v2.org.quartz.simpl.SimpleThreadPool$WorkerThread.run(SimpleThreadPool.java:577)22:35:09 localhost-startStop-1 INFO [standard]  Job GROUP_GENERATE.NAME_GENERATE removed.22:35:09 localhost-startStop-1 INFO [standard]  ADD JOB: NAME_GENERATE22:35:09 localhost-startStop-1 INFO [standard]  Job CloudAnalytics.treasureClean removed.22:35:09 localhost-startStop-1 INFO [standard]  ADD JOB: treasureClean22:35:09 localhost-startStop-1 INFO [standard]  Job CloudAnalytics.treasureExport removed.22:35:09 localhost-startStop-1 INFO [standard]  ADD JOB: treasureExport22:35:09 localhost-startStop-1 INFO [standard]  Job CloudAnalytics.treasureUpload removed.22:35:09 localhost-startStop-1 INFO [standard]  ADD JOB: treasureUpload22:35:09 localhost-startStop-1 INFO [standard]  Job CloudAnalytics.treasureUploadCheck removed.22:35:09 localhost-startStop-1 INFO [standard]  ADD JOB: treasureUploadCheck22:35:09 localhost-startStop-1 INFO [standard]  Job CloudAnalytics.systemRemind removed.22:35:09 localhost-startStop-1 INFO [standard]  ADD JOB: systemRemind22:35:09 localhost-startStop-1 INFO [standard]  Job CloudAnalytics.pluginDetect removed.22:35:09 localhost-startStop-1 INFO [standard]  ADD JOB: pluginDetect22:35:09 localhost-startStop-1 INFO [standard]  ADD JOB: pluginVersionCollect22:35:09 localhost-startStop-1 INFO [standard]  Job SolidAnalytics.solidExport removed.22:35:09 localhost-startStop-1 INFO [standard]  ADD JOB: solidExport22:35:09 localhost-startStop-1 INFO [standard]  Job SolidAnalytics.solidExportCheck removed.22:35:09 localhost-startStop-1 INFO [standard]  ADD JOB: solidExportCheck22:35:09 localhost-startStop-1 INFO [standard]  ADD JOB: appearanceConfig22:35:09 localhost-startStop-1 INFO [standard]  Job CloudAnalyticsCollector.authorityAssign removed.22:35:09 localhost-startStop-1 INFO [standard]  ADD JOB: authorityAssign22:35:09 localhost-startStop-1 INFO [standard]  Job CloudAnalyticsCollector.confEntity removed.22:35:09 localhost-startStop-1 INFO [standard]  ADD JOB: confEntity22:35:09 localhost-startStop-1 INFO [standard]  Job CloudAnalyticsCollector.containerMessage removed.22:35:09 localhost-startStop-1 INFO [standard]  ADD JOB: containerMessage22:35:09 localhost-startStop-1 INFO [standard]  Job CloudAnalyticsCollector.customerMessage removed.22:35:09 localhost-startStop-1 INFO [standard]  ADD JOB: customerMessage22:35:09 localhost-startStop-1 INFO [standard]  Job CloudAnalyticsCollector.dataSetUsage removed.22:35:09 localhost-startStop-1 INFO [standard]  ADD JOB: dataSetUsage22:35:09 localhost-startStop-1 INFO [standard]  Job CloudAnalyticsCollector.functionPossess removed.22:35:09 localhost-startStop-1 INFO [standard]  ADD JOB: functionPossess22:35:09 localhost-startStop-1 INFO [standard]  Job CloudAnalyticsCollector.pluginUsage removed.22:35:09 localhost-startStop-1 INFO [standard]  ADD JOB: pluginUsage22:35:09 localhost-startStop-1 INFO [standard]  Job CloudAnalyticsCollector.realTime removed.22:35:09 localhost-startStop-1 INFO [standard]  ADD JOB: realTime22:35:09 localhost-startStop-1 INFO [standard]  Job CloudAnalyticsCollector.userManagement removed.22:35:09 localhost-startStop-1 INFO [standard]  ADD JOB: userManagement22:35:09 localhost-startStop-1 INFO [standard]  ADD JOB: platformMessage22:35:09 localhost-startStop-1 INFO [standard]  ADD JOB: foreignPhone22:35:09 localhost-startStop-1 INFO [standard]  Job CloudAnalyticsCollector.clusterConf removed.22:35:09 localhost-startStop-1 INFO [standard]  ADD JOB: clusterConf22:35:09 localhost-startStop-1 INFO [standard]  Job CloudAnalyticsCollector.connection removed.22:35:10 localhost-startStop-1 INFO [standard]  ADD JOB: connection22:35:10 localhost-startStop-1 INFO [standard]  Job CloudAnalyticsCollector.directoryUsage removed.22:35:10 localhost-startStop-1 INFO [standard]  ADD JOB: directoryUsage22:35:10 localhost-startStop-1 INFO [standard]  Job CloudAnalyticsCollector.scheduleUsage removed.22:35:10 localhost-startStop-1 INFO [standard]  ADD JOB: scheduleUsage22:35:10 localhost-startStop-1 INFO [standard]  Job CloudAnalyticsCollector.tplInfo removed.22:35:10 localhost-startStop-1 INFO [standard]  ADD JOB: tplInfo22:35:10 localhost-startStop-1 INFO [standard]  Job CloudAnalyticsCollector.workflowUsage removed.22:35:10 localhost-startStop-1 INFO [standard]  ADD JOB: workflowUsage22:35:10 localhost-startStop-1 INFO [standard]  ADD JOB: sqlFrequency22:35:10 localhost-startStop-1 INFO [standard]  Job CloudAnalyticsCollector.BIFunctionPossess removed.22:35:10 localhost-startStop-1 INFO [standard]  ADD JOB: BIFunctionPossess22:35:10 localhost-startStop-1 INFO [standard]  Job CloudAnalyticsCollector.BIUserUsage removed.22:35:10 localhost-startStop-1 INFO [standard]  ADD JOB: BIUserUsage22:35:10 localhost-startStop-1 INFO [standard]  Job CloudAnalyticsCollector.BIScheduleUsage removed.22:35:10 localhost-startStop-1 INFO [standard]  ADD JOB: BIScheduleUsage22:35:10 localhost-startStop-1 INFO [standard]  Job CloudAnalyticsCollector.BIDirectoryUsage removed.22:35:10 localhost-startStop-1 INFO [standard]  ADD JOB: BIDirectoryUsage22:35:10 localhost-startStop-1 INFO [standard]  ADD JOB: BITableSumCollectTask22:35:10 localhost-startStop-1 INFO [standard]  Job CloudAnalytics.treasureClean removed.22:35:10 localhost-startStop-1 INFO [standard]  ADD JOB: treasureClean22:35:10 localhost-startStop-1 INFO [standard]  Job CloudAnalytics.treasureExport removed.22:35:10 localhost-startStop-1 INFO [standard]  ADD JOB: treasureExport22:35:10 localhost-startStop-1 INFO [standard]  Job CloudAnalytics.treasureUpload removed.22:35:10 localhost-startStop-1 INFO [standard]  ADD JOB: treasureUpload22:35:10 localhost-startStop-1 INFO [standard]  Job CloudAnalytics.treasureUploadCheck removed.22:35:10 localhost-startStop-1 INFO [standard]  ADD JOB: treasureUploadCheck22:35:10 localhost-startStop-1 INFO [standard]  Job CloudAnalytics.systemRemind removed.22:35:10 localhost-startStop-1 INFO [standard]  ADD JOB: systemRemind22:35:10 localhost-startStop-1 INFO [standard]  Job CloudAnalytics.pluginDetect removed.22:35:10 localhost-startStop-1 INFO [standard]  ADD JOB: pluginDetect22:35:10 localhost-startStop-1 INFO [standard]  Job CloudAnalytics.pluginVersionCollect removed.22:35:10 localhost-startStop-1 INFO [standard]  ADD JOB: pluginVersionCollect22:35:10 localhost-startStop-1 INFO [standard]  Job SolidAnalytics.solidExport removed.22:35:10 localhost-startStop-1 INFO [standard]  ADD JOB: solidExport22:35:10 localhost-startStop-1 INFO [standard]  Job SolidAnalytics.solidExportCheck removed.22:35:10 localhost-startStop-1 INFO [standard]  ADD JOB: solidExportCheck22:35:10 localhost-startStop-1 INFO [standard]  Job CloudAnalyticsCollector.appearanceConfig removed.22:35:10 localhost-startStop-1 INFO [standard]  ADD JOB: appearanceConfig22:35:10 localhost-startStop-1 INFO [standard]  Job CloudAnalyticsCollector.authorityAssign removed.22:35:10 localhost-startStop-1 INFO [standard]  ADD JOB: authorityAssign22:35:10 localhost-startStop-1 INFO [standard]  Job CloudAnalyticsCollector.confEntity removed.22:35:10 localhost-startStop-1 INFO [standard]  ADD JOB: confEntity22:35:10 localhost-startStop-1 INFO [standard]  Job CloudAnalyticsCollector.containerMessage removed.22:35:10 localhost-startStop-1 INFO [standard]  ADD JOB: containerMessage22:35:10 localhost-startStop-1 INFO [standard]  Job CloudAnalyticsCollector.customerMessage removed.22:35:10 localhost-startStop-1 INFO [standard]  ADD JOB: customerMessage22:35:10 localhost-startStop-1 INFO [standard]  Job CloudAnalyticsCollector.dataSetUsage removed.22:35:10 localhost-startStop-1 INFO [standard]  ADD JOB: dataSetUsage22:35:10 localhost-startStop-1 INFO [standard]  Job CloudAnalyticsCollector.functionPossess removed.22:35:10 localhost-startStop-1 INFO [standard]  ADD JOB: functionPossess22:35:10 localhost-startStop-1 INFO [standard]  Job CloudAnalyticsCollector.pluginUsage removed.22:35:10 localhost-startStop-1 INFO [standard]  ADD JOB: pluginUsage22:35:10 localhost-startStop-1 INFO [standard]  Job CloudAnalyticsCollector.realTime removed.22:35:10 localhost-startStop-1 INFO [standard]  ADD JOB: realTime22:35:10 localhost-startStop-1 INFO [standard]  Job CloudAnalyticsCollector.userManagement removed.22:35:10 localhost-startStop-1 INFO [standard]  ADD JOB: userManagement22:35:10 localhost-startStop-1 INFO [standard]  Job CloudAnalyticsCollector.platformMessage removed.22:35:10 localhost-startStop-1 INFO [standard]  ADD JOB: platformMessage22:35:10 localhost-startStop-1 INFO [standard]  Job CloudAnalyticsCollector.foreignPhone removed.22:35:10 localhost-startStop-1 INFO [standard]  ADD JOB: foreignPhone22:35:10 localhost-startStop-1 INFO [standard]  Job CloudAnalyticsCollector.clusterConf removed.22:35:10 localhost-startStop-1 INFO [standard]  ADD JOB: clusterConf22:35:10 localhost-startStop-1 INFO [standard]  Job CloudAnalyticsCollector.connection removed.22:35:10 localhost-startStop-1 INFO [standard]  ADD JOB: connection22:35:10 localhost-startStop-1 INFO [standard]  Job CloudAnalyticsCollector.directoryUsage removed.22:35:10 localhost-startStop-1 INFO [standard]  ADD JOB: directoryUsage22:35:10 localhost-startStop-1 INFO [standard]  Job CloudAnalyticsCollector.scheduleUsage removed.22:35:10 localhost-startStop-1 INFO [standard]  ADD JOB: scheduleUsage22:35:10 localhost-startStop-1 INFO [standard]  Job CloudAnalyticsCollector.tplInfo removed.22:35:10 localhost-startStop-1 INFO [standard]  ADD JOB: tplInfo22:35:10 localhost-startStop-1 INFO [standard]  Job CloudAnalyticsCollector.workflowUsage removed.22:35:10 localhost-startStop-1 INFO [standard]  ADD JOB: workflowUsage22:35:10 localhost-startStop-1 INFO [standard]  Job CloudAnalyticsCollector.sqlFrequency removed.22:35:10 localhost-startStop-1 INFO [standard]  ADD JOB: sqlFrequency22:35:10 localhost-startStop-1 INFO [standard]  Job CloudAnalyticsCollector.BIFunctionPossess removed.22:35:10 localhost-startStop-1 INFO [standard]  ADD JOB: BIFunctionPossess22:35:10 localhost-startStop-1 INFO [standard]  Job CloudAnalyticsCollector.BIUserUsage removed.22:35:10 localhost-startStop-1 INFO [standard]  ADD JOB: BIUserUsage22:35:10 localhost-startStop-1 INFO [standard]  Job CloudAnalyticsCollector.BIScheduleUsage removed.22:35:10 localhost-startStop-1 INFO [standard]  ADD JOB: BIScheduleUsage22:35:10 localhost-startStop-1 INFO [standard]  Job CloudAnalyticsCollector.BIDirectoryUsage removed.22:35:10 localhost-startStop-1 INFO [standard]  ADD JOB: BIDirectoryUsage22:35:10 localhost-startStop-1 INFO [standard]  Job CloudAnalyticsCollector.BITableSumCollectTask removed.22:35:10 localhost-startStop-1 INFO [standard]  ADD JOB: BITableSumCollectTask22:35:10 localhost-startStop-1 INFO [standard]  Scheduler has been started...22:35:10 localhost-startStop-1 INFO [standard]  Module SchedulerActivator started.Time used 11088 ms.22:35:10 localhost-startStop-1 INFO [standard]  Module ServerUpdateActivator starting...22:35:10 localhost-startStop-1 INFO [standard]  Job updateTask.plugins-0 0 23 ? * * removed.22:35:10 localhost-startStop-1 INFO [standard]  ADD JOB: plugins-0 0 23 ? * *22:35:10 localhost-startStop-1 INFO [standard]  Module ServerUpdateActivator started.Time used 4 ms.22:35:11 localhost-startStop-1 INFO [standard]  Module AttachmentActivator starting...22:35:11 localhost-startStop-1 INFO [standard]  Module AttachmentActivator started.Time used 7 ms.22:35:11 localhost-startStop-1 INFO [standard]  Module ClusterAssistActivator starting...22:35:11 localhost-startStop-1 INFO [standard]  Job health.redisNodeLeft removed.22:35:11 localhost-startStop-1 INFO [standard]  ADD JOB: redisNodeLeft22:35:11 localhost-startStop-1 INFO [standard]  Job health.fileServerCrash removed.22:35:11 localhost-startStop-1 INFO [standard]  ADD JOB: fileServerCrash22:35:11 localhost-startStop-1 INFO [standard]  Module ClusterAssistActivator started.Time used 23 ms.22:35:11 localhost-startStop-1 INFO [standard]  Module DataActivator starting...22:35:11 localhost-startStop-1 INFO [standard]  Module DataActivator started.Time used 0 ms.22:35:11 localhost-startStop-1 INFO [standard]  Module VirtualActivator starting...22:35:11 localhost-startStop-1 INFO [standard]  Module LogImplActivator starting...22:35:11 localhost-startStop-1 INFO [standard]  Module LogImplActivator started.Time used 5 ms.22:35:11 localhost-startStop-1 INFO [standard]  Module SwiftEngineActivator starting...22:35:11 localhost-startStop-1 INFO [standard]  fineio read memory size 214748364822:35:11 localhost-startStop-1 INFO [standard]  fineio write memory size 87772446722:35:11 localhost-startStop-1 INFO [standard]  fineio buffer cache maximumWeight 107374182422:35:11 localhost-startStop-1 INFO [standard]  cache invalidate com.fr.io.base.ResourcePathConfig22:35:11 localhost-startStop-1 INFO [standard]  cache invalidate com.fr.io.base.ResourcePathConfig22:35:11 localhost-startStop-1 INFO [standard]  cache invalidate com.fr.io.base.ResourcePathConfig22:35:11 localhost-startStop-1 INFO [standard]  swift engine started22:35:11 localhost-startStop-1 INFO [standard]  Module SwiftEngineActivator started.Time used 366 ms.22:35:11 localhost-startStop-1 INFO [standard]  Module IntelligenceActivator starting...22:35:11 localhost-startStop-1 INFO [standard]  Module IntelligenceActivator started.Time used 1 ms.22:35:11 localhost-startStop-1 INFO [standard]  Module RecordErrorLogAppenderActivator starting...22:35:11 localhost-startStop-1 INFO [standard]  Module RecordErrorLogAppenderActivator started.Time used 24 ms.22:35:11 localhost-startStop-1 INFO [standard]  Module CloudAnalysisActivator starting...22:35:11 localhost-startStop-1 INFO [standard]  Job GROUP_CONNECTION.NAME_CONNECTION removed.22:35:11 localhost-startStop-1 INFO [standard]  ADD JOB: NAME_CONNECTION22:35:11 localhost-startStop-1 INFO [standard]  Module CloudAnalysisActivator started.Time used 17 ms.22:35:11 localhost-startStop-1 INFO [standard]  Module LogCacheRecoveryActivator starting...22:35:11 localhost-startStop-1 INFO [standard]  Module LogCacheRecoveryActivator started.Time used 426 ms.22:35:11 localhost-startStop-1 INFO [standard]  Module VirtualActivator started.Time used 872 ms.22:35:11 localhost-startStop-1 INFO [standard]  Module AtomActivator starting...22:35:11 localhost-startStop-1 INFO [standard]  Module AtomActivator started.Time used 0 ms.22:35:11 localhost-startStop-1 INFO [standard]  Module ServerWorkspaceRegister starting...22:35:11 localhost-startStop-1 INFO [standard]  Module ServerWorkspaceRegister started.Time used 2 ms.22:35:11 localhost-startStop-1 INFO [standard]  Module VirtualActivator started.Time used 34775 ms.22:35:11 localhost-startStop-1 INFO [standard]  Module DecisionActivator starting...22:35:11 localhost-startStop-1 INFO [standard]  register cache: com.fr.decision.webservice.v10.entry.cache.EntryTreeCache22:35:11 localhost-startStop-1 INFO [standard]  register cache: com.fr.decision.webservice.v10.entry.cache.EntryTreeNodeCache22:35:11 localhost-startStop-1 INFO [standard]  register cache: com.fr.decision.webservice.v10.entry.cache.HomePageCache22:35:11 localhost-startStop-1 INFO [standard]  register cache: com.fr.decision.webservice.v10.entry.cache.HomePageNodeCache22:35:11 localhost-startStop-1 INFO [standard]  register cache: com.fr.decision.webservice.v10.international.cache.InternationalCache22:35:11 localhost-startStop-1 INFO [standard]  cache invalidate com.fr.decision.config.DecisionVersionConfig22:35:11 localhost-startStop-1 INFO [standard]  Module DecisionServletInitializer starting...22:35:12 localhost-startStop-1 INFO [standard]  Server started with build: Build#persist-2021.08.02.09.38.40.44022:35:12 localhost-startStop-1 INFO [standard]  Module DecisionServletInitializer started.Time used 63 ms.22:35:12 localhost-startStop-1 INFO [standard]  Module DecisionDBActivator starting...22:35:12 localhost-startStop-1 INFO [standard]  Persistence strategy NONE is set for cache, below properties will not be applied:diskStore, maxBytesLocalDisk22:35:12 localhost-startStop-1 INFO [com.fr.third.alibaba.druid.pool.DruidDataSource]  testOnBorrow is true, validationQuery not set22:35:12 localhost-startStop-1 INFO [com.fr.third.alibaba.druid.pool.DruidDataSource]  {dataSource-5} inited22:35:13 localhost-startStop-1 INFO [standard]  Using cache: com.fr.third.org.hibernate.cache.spi.UpdateTimestampsCache.22:35:13 CommonExecutor-1-thread-1 INFO [com.fr.third.alibaba.druid.pool.DruidDataSource]  testOnBorrow is true, validationQuery not set22:35:13 CommonExecutor-1-thread-1 INFO [com.fr.third.alibaba.druid.pool.DruidDataSource]  {dataSource-6} inited22:35:13 localhost-startStop-1 INFO [standard]  Using cache: com.fr.third.org.hibernate.cache.internal.StandardQueryCache.22:35:13 localhost-startStop-1 INFO [standard]  Using cache: com.fr.report.entity.OffsetIPRelativeEntity.22:35:13 localhost-startStop-1 INFO [standard]  Using cache: com.fr.decision.authority.entity.SoftDataEntity.22:35:13 localhost-startStop-1 INFO [standard]  Using cache: com.fr.decision.finebi.entity.report.ReportIndexEntity.22:35:13 localhost-startStop-1 INFO [standard]  Using cache: com.fr.schedule.base.entity.ScheduleResultParamEntity.22:35:14 localhost-startStop-1 INFO [standard]  Using cache: com.fr.decision.authority.entity.AuthorityObjectEntity.22:35:14 localhost-startStop-1 INFO [standard]  Using cache: com.fr.decision.system.entity.message.SystemMessageEntity.22:35:14 localhost-startStop-1 INFO [standard]  Using cache: com.fr.decision.system.entity.InternationalEntity.22:35:14 localhost-startStop-1 INFO [standard]  Using cache: com.fr.decision.workflow.bean.entity.WorkflowStashEntity.22:35:14 localhost-startStop-1 INFO [standard]  Using cache: com.fr.decision.authority.entity.HomePageExpandAuthorityObjectEntity.22:35:14 localhost-startStop-1 INFO [standard]  Using cache: com.fr.schedule.base.entity.output.BaseOutputActionEntity.22:35:14 localhost-startStop-1 INFO [standard]  Using cache: com.fr.decision.finebi.entity.share.ShareIndexEntity.22:35:14 localhost-startStop-1 INFO [standard]  Using cache: com.finebi.update.monitor.db.entity.UpdateTaskEntity.22:35:14 localhost-startStop-1 INFO [standard]  Using cache: com.fr.schedule.base.entity.output.OutputSFtpEntity.22:35:14 localhost-startStop-1 INFO [standard]  Using cache: com.fr.decision.finebi.entity.authority.BiReportExpandAuthorityObjectEntity.22:35:14 localhost-startStop-1 INFO [standard]  Using cache: com.fr.decision.finebi.entity.authority.PackageRowFilterEntity.22:35:14 localhost-startStop-1 INFO [standard]  Using cache: com.fr.decision.workflow.bean.entity.WorkflowTaskEntity.22:35:14 localhost-startStop-1 INFO [standard]  Using cache: com.fr.decision.authority.entity.AuthorityEntity.22:35:14 localhost-startStop-1 INFO [standard]  Using cache: com.fr.decision.authority.entity.DepartmentEntity.22:35:14 localhost-startStop-1 INFO [standard]  Using cache: com.fr.schedule.base.entity.output.OutputPrintEntity.22:35:14 localhost-startStop-1 INFO [standard]  Using cache: com.fr.schedule.base.entity.output.OutputMountEntity.22:35:14 localhost-startStop-1 INFO [standard]  Using cache: com.fr.schedule.base.entity.ScheduleTaskEntity.22:35:14 localhost-startStop-1 INFO [standard]  Using cache: com.fr.schedule.base.entity.output.OutputClassEntity.22:35:14 localhost-startStop-1 INFO [standard]  Using cache: com.fr.decision.workflow.bean.entity.WorkflowTaskImplEntity.22:35:14 localhost-startStop-1 INFO [standard]  Using cache: com.fr.schedule.base.entity.output.OutputClientNotificationEntity.22:35:14 localhost-startStop-1 INFO [standard]  Using cache: com.fr.decision.label.entity.LabelIndexEntity.22:35:14 localhost-startStop-1 INFO [standard]  Using cache: com.fr.decision.authority.entity.PostEntity.22:35:14 localhost-startStop-1 INFO [standard]  Using cache: com.fr.decision.system.entity.message.MobileMessageEntity.22:35:14 localhost-startStop-1 INFO [standard]  Using cache: com.fr.decision.mobile.entity.MobileDeviceEntity.22:35:14 localhost-startStop-1 INFO [standard]  Using cache: com.fr.decision.system.entity.BackupNodeEntity.22:35:14 localhost-startStop-1 INFO [standard]  Using cache: com.fr.decision.workflow.bean.WorkflowNode.22:35:14 localhost-startStop-1 INFO [standard]  Using cache: com.fr.decision.finebi.entity.report.FavoriteReportEntity.22:35:14 localhost-startStop-1 INFO [standard]  Using cache: com.fr.schedule.base.entity.output.OutputFtpEntity.22:35:14 localhost-startStop-1 INFO [standard]  Using cache: com.fr.decision.finebi.entity.report.ReportStyleEntity.22:35:14 localhost-startStop-1 INFO [standard]  Using cache: com.fr.schedule.base.entity.output.OutputPlatformMSGEntity.22:35:14 localhost-startStop-1 INFO [standard]  Using cache: com.fr.decision.authority.controller.provider.expander.entity.ProcessExpandAuthorityObjectEntity.22:35:14 localhost-startStop-1 INFO [standard]  Using cache: com.fr.decision.system.entity.message.ProcessMessageEntity.22:35:14 localhost-startStop-1 INFO [standard]  Using cache: com.fr.decision.workflow.bean.WorkflowLog.22:35:14 localhost-startStop-1 INFO [standard]  Using cache: com.fr.decision.authority.entity.DepRoleEntity.22:35:14 localhost-startStop-1 INFO [standard]  Using cache: com.fr.report.entity.RemoteDesignAuthorityEntity.22:35:14 localhost-startStop-1 INFO [standard]  Using cache: com.fr.decision.system.entity.LoginDetailInfoEntity.22:35:14 localhost-startStop-1 INFO [standard]  Using cache: com.fr.schedule.base.entity.ScheduleRecordEntity.22:35:15 localhost-startStop-1 INFO [standard]  Using cache: com.finebi.update.monitor.db.entity.UpdateDetailEntity.22:35:15 localhost-startStop-1 INFO [standard]  Using cache: com.fr.report.entity.ParamsTemplateEntity.22:35:15 localhost-startStop-1 INFO [standard]  Using cache: com.fr.decision.finebi.entity.report.ReportWarningEntity.22:35:15 localhost-startStop-1 INFO [standard]  Using cache: com.fr.decision.system.entity.FavoriteEntryEntity.22:35:15 localhost-startStop-1 INFO [standard]  Using cache: com.fr.report.entity.PrintOffsetEntity.22:35:15 localhost-startStop-1 INFO [standard]  Using cache: com.fr.decision.system.entity.LoginLockEntity.22:35:15 localhost-startStop-1 INFO [standard]  Using cache: com.fr.decision.authority.entity.CustomRoleEntity.22:35:15 localhost-startStop-1 INFO [standard]  Using cache: com.finebi.update.monitor.db.entity.UpdateDetailInfoEntity.22:35:15 localhost-startStop-1 INFO [standard]  Using cache: com.fr.schedule.base.entity.ScheduleOutputEntity.22:35:15 localhost-startStop-1 INFO [standard]  Using cache: com.fr.decision.workflow.bean.entity.WorkflowEntity.22:35:15 localhost-startStop-1 INFO [standard]  Using cache: com.fr.decision.authority.entity.ExtraPropertyEntity.22:35:15 localhost-startStop-1 INFO [standard]  Using cache: com.fr.decision.usage.entity.UsageDataEntity.22:35:15 localhost-startStop-1 INFO [standard]  Using cache: com.fr.decision.finebi.entity.report.ReportLinkEntity.22:35:15 localhost-startStop-1 INFO [standard]  Using cache: com.fr.decision.authority.entity.UserRoleMiddleEntity.22:35:15 localhost-startStop-1 INFO [standard]  Using cache: com.fr.decision.finebi.entity.report.ReportTablesIndexEntity.22:35:15 localhost-startStop-1 INFO [standard]  Using cache: com.fr.report.write.entity.WriteStashEntity.22:35:15 localhost-startStop-1 INFO [standard]  Using cache: com.fr.decision.system.entity.message.MessageEntity.22:35:15 localhost-startStop-1 INFO [standard]  Using cache: com.fr.schedule.base.entity.output.OutputEmailEntity.22:35:15 localhost-startStop-1 INFO [standard]  Using cache: com.fr.decision.authority.controller.provider.expander.entity.ReportExpandAuthorityObjectEntity.22:35:15 localhost-startStop-1 INFO [standard]  Using cache: com.fr.schedule.base.entity.output.OutputSMSEntity.22:35:15 localhost-startStop-1 INFO [standard]  Using cache: com.fr.decision.security.entity.BlockIpEntity.22:35:15 localhost-startStop-1 INFO [standard]  Using cache: com.fr.decision.authority.entity.UserEntity.22:35:15 localhost-startStop-1 INFO [standard]  Using cache: com.fr.decision.label.entity.LabelEntity.22:35:15 CommonExecutor-1-thread-1 INFO [standard]  swift collate executor started22:35:15 CommonExecutor-1-thread-1 INFO [standard]  swift core service collateExecutor started22:35:15 CommonExecutor-1-thread-1 INFO [standard]  Swift FineIO memory scale service start!22:35:15 CommonExecutor-1-thread-1 INFO [standard]  swift core service fineIOMemoryScaleExecutor started22:35:15 CommonExecutor-1-thread-1 INFO [standard]  swift get pre-jobs:com.fr.intelli.pretreatment.PretreatmentJobKeyFactory$1@68f1f7a822:35:15 CommonExecutor-1-thread-1 INFO [standard]  swift get pre-jobs:com.fr.intelli.pretreatment.PretreatmentJobKeyFactory$1@66735f8422:35:15 CommonExecutor-1-thread-1 INFO [standard]  swift get pre-jobs:com.fr.intelli.pretreatment.PretreatmentJobKeyFactory$1@f46983ad22:35:15 CommonExecutor-1-thread-1 INFO [standard]  swift get pre-jobs:com.fr.intelli.pretreatment.PretreatmentJobKeyFactory$1@f237fe4922:35:15 CommonExecutor-1-thread-1 INFO [standard]  swift core service swiftDaysRecordGeneratorService started22:35:15 CommonExecutor-1-thread-1 INFO [standard]  swift core service scheduledRealtimeTransfer started22:35:15 CommonExecutor-1-thread-1 INFO [standard]  swift core service schedSegLocCacheRefresher started22:35:15 CommonExecutor-1-thread-1 INFO [standard]  swift core service taskDispatcher started22:35:15 CommonExecutor-1-thread-1 INFO [standard]  swift core service swiftEventDispatcher started22:35:15 CommonExecutor-1-thread-1 INFO [standard]  swift core service rpcClient started22:35:15 CommonExecutor-1-thread-1 INFO [standard]  swift core service queryCacheBuilder started22:35:15 TaskDispatcher$DispatchRunnable INFO [standard]  read external conflict-conf.json !22:35:15 TaskDispatcher$DispatchRunnable WARN [standard]  Failed to read external conflict-conf.json, read internal conflict-conf.json instead!22:35:15 TaskExecuteRunnable-0 WARN [standard]  removed non exists real time seg [fine_operation_process_log@MEMORY@0]22:35:15 TaskExecuteRunnable-1 WARN [standard]  removed non exists real time seg [fine_real_time_usage@MEMORY@0]22:35:15 TaskExecuteRunnable-0 WARN [standard]  removed non exists real time seg [fine_operation_process_log@MEMORY@0]22:35:15 TaskExecuteRunnable-1 WARN [standard]  removed non exists real time seg [fine_real_time_usage@MEMORY@0]22:35:15 TaskExecuteRunnable-0 WARN [standard]  removed non exists real time seg [fine_intelli_focus_point@MEMORY@0]22:35:15 TaskExecuteRunnable-0 WARN [standard]  removed non exists real time seg [fine_intelli_focus_point@MEMORY@0]22:35:15 TaskExecuteRunnable-1 WARN [standard]  removed non exists real time seg [fine_record_gc@MEMORY@0]22:35:15 TaskExecuteRunnable-1 WARN [standard]  removed non exists real time seg [fine_record_gc@MEMORY@0]22:35:15 TaskExecuteRunnable-0 WARN [standard]  removed non exists real time seg [fine_record_login@MEMORY@0]22:35:15 TaskExecuteRunnable-0 WARN [standard]  removed non exists real time seg [fine_record_login@MEMORY@0]22:35:15 TaskExecuteRunnable-1 WARN [standard]  removed non exists real time seg [fine_update_task@MEMORY@0]22:35:15 TaskExecuteRunnable-1 WARN [standard]  removed non exists real time seg [fine_update_task@MEMORY@0]22:35:16 localhost-startStop-1 INFO [standard]  Module DecisionDBActivator started.Time used 4209 ms.22:35:16 localhost-startStop-1 INFO [standard]  Module AuthorityActivator starting...22:35:16 localhost-startStop-1 INFO [standard]  Authority refer initialize OK22:35:16 AliasDataCheckerOperator-26-worker-1 INFO [standard]  generate alias over, use 66ms22:35:16 localhost-startStop-1 INFO [standard]  Module AuthorityActivator started.Time used 635 ms.22:35:16 localhost-startStop-1 INFO [standard]  Module UpdateHandlerActivator starting...22:35:16 localhost-startStop-1 INFO [standard]  Module UpdateHandlerActivator started.Time used 0 ms.22:35:16 localhost-startStop-1 INFO [standard]  Module WebServiceActivator starting...22:35:16 localhost-startStop-1 INFO [standard]  GarbageCollection monitor: Register PS Scavenge for [PS Eden Space, PS Survivor Space].22:35:16 localhost-startStop-1 INFO [standard]  GarbageCollection monitor: Register PS MarkSweep for [PS Eden Space, PS Survivor Space, PS Old Gen].22:35:16 localhost-startStop-1 INFO [standard]  Gc notification monitor choose GcNotificationMonitor22:35:16 localhost-startStop-1 INFO [standard]  Current jvm vendor:Oracle Corporation22:35:17 localhost-startStop-1 INFO [standard]  cache invalidate com.fr.decision.config.BackupConfig22:35:17 localhost-startStop-1 INFO [standard]  cache invalidate com.fr.decision.config.BackupConfig22:35:17 localhost-startStop-1 INFO [standard]  cache invalidate com.fr.decision.config.BackupConfig22:35:17 localhost-startStop-1 INFO [standard]  Job GROUP_REMOVE.REMOVE_TIMEOUT_SESSION removed.22:35:17 localhost-startStop-1 INFO [standard]  ADD JOB: REMOVE_TIMEOUT_SESSION22:35:17 localhost-startStop-1 INFO [standard]  cache invalidate com.fr.security.SecurityConfig22:35:17 localhost-startStop-1 INFO [standard]  cache invalidate com.fr.security.SecurityConfig22:35:17 localhost-startStop-1 INFO [standard]  Module URLAliasActivator starting...22:35:17 localhost-startStop-1 INFO [standard]  Module URLAliasActivator started.Time used 2 ms.22:35:17 localhost-startStop-1 INFO [standard]  Module RegisterServiceActivator starting...22:35:17 localhost-startStop-1 INFO [standard]  Module RegisterServiceActivator started.Time used 0 ms.22:35:17 localhost-startStop-1 INFO [standard]  Module SystemMonitorActivator starting...22:35:17 localhost-startStop-1 INFO [standard]  Module SystemMonitorActivator started.Time used 0 ms.22:35:17 localhost-startStop-1 INFO [standard]  Module SwiftLogSearchProviderActivator starting...22:35:17 localhost-startStop-1 INFO [standard]  Module SwiftLogSearchProviderActivator started.Time used 5 ms.22:35:17 localhost-startStop-1 INFO [standard]  Module BackupActivator starting...22:35:17 localhost-startStop-1 INFO [standard]  Module BackupActivator started.Time used 4 ms.22:35:17 localhost-startStop-1 INFO [standard]  Module PluginServiceActivator starting...22:35:17 localhost-startStop-1 INFO [standard]  Module PluginServiceActivator started.Time used 9 ms.22:35:17 localhost-startStop-1 INFO [standard]  Module PluginControllerActivator starting...22:35:17 localhost-startStop-1 INFO [standard]  Module PluginControllerActivator started.Time used 3 ms.22:35:17 localhost-startStop-1 INFO [standard]  Module DecisionUpdateActivator starting...22:35:17 localhost-startStop-1 INFO [standard]  cache invalidate com.fr.decision.config.PasswordStrategyConfig22:35:17 localhost-startStop-1 INFO [standard]  Module DecisionUpdateActivator started.Time used 50 ms.22:35:17 localhost-startStop-1 INFO [standard]  Module DecisionPointActivator starting...22:35:17 localhost-startStop-1 INFO [standard]  Module DecisionPointActivator started.Time used 0 ms.22:35:17 localhost-startStop-1 INFO [standard]  Module WebServiceActivator started.Time used 659 ms.22:35:17 localhost-startStop-1 INFO [standard]  Module GEOJSONActivator starting...22:35:17 localhost-startStop-1 INFO [standard]  Module GEOJSONActivator started.Time used 0 ms.22:35:17 localhost-startStop-1 INFO [standard]  Module DecisionMessageActivator starting...22:35:17 localhost-startStop-1 INFO [standard]  Module DecisionMessageActivator started.Time used 4 ms.22:35:17 localhost-startStop-1 INFO [standard]  Module MessageRecorderActivator starting...22:35:17 localhost-startStop-1 INFO [standard]  Module MessageRecorderActivator started.Time used 8 ms.22:35:17 localhost-startStop-1 INFO [standard]  Module DecisionActivator started.Time used 5890 ms.22:35:17 localhost-startStop-1 INFO [standard]  Module WebSocketActivator starting...22:35:18 nioEventLoopGroup-2-1 INFO [standard]  WebSocket server started at port:3888822:35:18 localhost-startStop-1 INFO [standard]  Module WebSocketActivator started.Time used 412 ms.22:35:18 localhost-startStop-1 INFO [standard]  Module VirtualActivator starting...22:35:18 localhost-startStop-1 INFO [standard]  Module WorkspaceServerActivator starting...22:35:18 localhost-startStop-1 INFO [standard]  Module WorkspaceServerActivator started.Time used 2 ms.22:35:18 localhost-startStop-1 INFO [standard]  Module ServerWorkspaceRegister starting...22:35:18 localhost-startStop-1 INFO [standard]  Module ServerWorkspaceRegister started.Time used 0 ms.22:35:18 localhost-startStop-1 INFO [standard]  Module SocketLogAppenderActivator starting...22:35:18 localhost-startStop-1 INFO [standard]  Module SocketLogAppenderActivator started.Time used 2 ms.22:35:18 localhost-startStop-1 INFO [standard]  Module ConfigSocketActivator starting...22:35:18 localhost-startStop-1 INFO [standard]  Module ConfigSocketActivator started.Time used 0 ms.22:35:18 localhost-startStop-1 INFO [standard]  Module VirtualActivator started.Time used 9 ms.22:35:18 localhost-startStop-1 INFO [standard]  Module ScheduleActivator starting...22:35:18 localhost-startStop-1 INFO [standard]  Module ScheduleActivator started.Time used 38 ms.22:35:18 localhost-startStop-1 INFO [standard]  Module ReportActivator starting...22:35:18 localhost-startStop-1 INFO [standard]  Module WriteActivator starting...22:35:18 localhost-startStop-1 INFO [standard]  Module WriteActivator started.Time used 29 ms.22:35:18 localhost-startStop-1 INFO [standard]  Module ReportAnalysisActivator starting...22:35:18 localhost-startStop-1 INFO [standard]  Module ReportAnalysisActivator started.Time used 0 ms.22:35:18 localhost-startStop-1 INFO [standard]  Module VcsFolderManagerActivator starting...22:35:18 localhost-startStop-1 INFO [standard]  Module VcsFolderManagerActivator started.Time used 0 ms.22:35:18 localhost-startStop-1 INFO [standard]  Module ReportActivator started.Time used 77 ms.22:35:18 localhost-startStop-1 INFO [standard]  Module DecisionActivator starting...22:35:18 localhost-startStop-1 INFO [standard]  cache invalidate com.fr.decision.config.BackupConfig22:35:18 localhost-startStop-1 INFO [standard]  Job updatePushGroup.updatePushTask removed.22:35:18 localhost-startStop-1 INFO [standard]  ADD JOB: updatePushTask22:35:18 localhost-startStop-1 INFO [standard]  Module WorkflowActivator starting...22:35:18 localhost-startStop-1 INFO [standard]  Module WorkflowActivator started.Time used 80 ms.22:35:18 localhost-startStop-1 INFO [standard]  Module DecisionActivator started.Time used 184 ms.22:35:18 localhost-startStop-1 INFO [standard]  Module ScheduleActivator starting...22:35:18 localhost-startStop-1 INFO [standard]  cache invalidate com.fr.decision.config.DecisionUpdateConfig22:35:18 localhost-startStop-1 INFO [standard]  Module ScheduleActivator started.Time used 293 ms.22:35:18 localhost-startStop-1 INFO [standard]  Module CompatibleFSServiceActivator starting...22:35:18 localhost-startStop-1 INFO [standard]  Module CompatibleFSServiceActivator started.Time used 0 ms.22:35:18 localhost-startStop-1 INFO [standard]  Module VirtualActivator starting...22:35:18 localhost-startStop-1 INFO [standard]  Module DecisionPreparationActivator starting...22:35:18 localhost-startStop-1 INFO [standard]  [Cluster] Fine lock: com.fr.decision.finebi.DecisionPreparationActivator locking.22:35:18 localhost-startStop-1 INFO [standard]  [Cluster] Fine lock: com.fr.decision.finebi.DecisionPreparationActivator locked.22:35:18 localhost-startStop-1 INFO [standard]  cache invalidate com.fr.decision.finebi.config.BIUpdateConfig22:35:18 localhost-startStop-1 INFO [standard]  [Cluster] Fine lock: com.fr.decision.finebi.DecisionPreparationActivator unlocking.22:35:18 localhost-startStop-1 INFO [standard]  [Cluster] Fine lock: com.fr.decision.finebi.DecisionPreparationActivator unlocked.22:35:18 localhost-startStop-1 INFO [standard]  Module DecisionPreparationActivator started.Time used 10 ms.22:35:18 localhost-startStop-1 INFO [standard]  Module FoundationActivator starting...22:35:18 localhost-startStop-1 INFO [standard]  cache invalidate com.finebi.config.BIJarVersionConfig22:35:18 localhost-startStop-1 INFO [standard]  --------->FoundationActivator start begin22:35:18 localhost-startStop-1 INFO [standard]  --------->start register js/css22:35:18 localhost-startStop-1 INFO [standard]  --------->end register js/css22:35:18 ForkJoinPool.commonPool-worker-1 INFO [standard]  ----------------- bi initializeMapAssets start22:35:18 localhost-startStop-1 INFO [standard]  register Encryption success! cost 0 ms22:35:18 localhost-startStop-1 INFO [standard]  register base-cell success! cost 10 ms22:35:18 localhost-startStop-1 INFO [standard]  register Config success! cost 16 ms22:35:18 localhost-startStop-1 INFO [standard]  CacheEvictExpiredScheduler working22:35:18 localhost-startStop-1 INFO [standard]  register CacheEvictExpiredScheduler success! cost 8 ms22:35:18 localhost-startStop-1 INFO [standard]  MemReaperRegister working22:35:18 localhost-startStop-1 INFO [standard]  register MemReaper success! cost 11 ms22:35:18 localhost-startStop-1 INFO [standard]  register POICacheFileClear success! cost 7 ms22:35:18 localhost-startStop-1 INFO [standard]  register CustomImage success! cost 2 ms22:35:18 localhost-startStop-1 INFO [standard]  --------->DirectFoundationActivator start begin22:35:18 localhost-startStop-1 WARN [standard]  register factory get key failed or not registered: 22:35:19 localhost-startStop-1 INFO [standard]  register excel-register success! cost 52 ms22:35:19 Thread-17 INFO [standard]  start registering com.finebi.direct.excel.ExcelDataSourceDriver 22:35:19 localhost-startStop-1 INFO [standard]  register direct-Cell success! cost 354 ms22:35:19 localhost-startStop-1 WARN [standard]  register factory get key failed or not registered: 22:35:19 Thread-18 INFO [standard]  start registering com.finebi.direct.common.impl.datasource.conf.ConfAnalysisDataSourceDriver 22:35:19 localhost-startStop-1 WARN [standard]  register factory get key failed or not registered: 22:35:19 Thread-19 INFO [standard]  start registering com.finebi.direct.common.impl.datasource.analysis.AnalysisDataSourceDriver 22:35:19 localhost-startStop-1 WARN [standard]  [plugin-bi-info-log][SwallowDunplicate] log message dunplicate for 5 times, message: register factory get key failed or not registered: 22:35:19 Thread-20 INFO [standard]  start registering com.finebi.direct.common.impl.datasource.sql.SqlDataSourceDriver 22:35:19 Thread-21 INFO [standard]  start registering com.finebi.direct.common.impl.datasource.database.DatabaseDataSourceDriver 22:35:19 Thread-18 INFO [standard]  end registering com.finebi.direct.common.impl.datasource.conf.ConfAnalysisDataSourceDriver, cost 5 ms22:35:19 localhost-startStop-1 INFO [standard]  register Model success! cost 48 ms22:35:19 Thread-19 INFO [standard]  end registering com.finebi.direct.common.impl.datasource.analys
FineBI 冰麒麟 发布于 2022-3-25 23:43
发布于2022-3-26 01:42
FineBI无法启动排查步骤-https://help.fanruan.com/finebi/doc-view-811.html
  • 541浏览人数
  • 最后回答于:2022-3-26 01:42
