帆软对于时间的分钟进行四舍五入如何做
比如    2022-4-14 12:10:36  得到  2022-4-14 12:00:00     2022-4-14 12:32:36  得到  2022-4-14 13:00:00
FineReport yzm263960 发布于 2022-4-14 15:55
krystal033Lv7高级互助
发布于2022-4-14 16:03(编辑于 2022-4-14 16:05)
if(MINUTE(a2)<30,CONCATENATE(FORMAT(a2,"yyyy-MM-dd")," ",hour(a2),":00:00"),CONCATENATE(FORMAT(a2,"yyyy-MM-dd")," ",format(hour(a2)+1,"00"),":00:00"))
a1改成你的时间单元格
发布于2022-4-14 16:06
if(MINUTE($$$)>29,format(todate(DATETONUMBER($$$)+3600000),"yyyy-MM-dd HH:00:00"),format($$$,"yyyy-MM-dd HH:00:00"))
  • 311浏览人数
  • 最后回答于:2022-4-14 16:06
