JS调用oracle存储过程不成功【返回的是游标】,在模板数据集是可以调用成功的
=== 过程如下
CREATE OR REPLACE procedure sp_upt_t30check(in_sWhere In Varchar2,in_sValue In Varchar2,out_rep Out SYS_REFCURSOR) Is
  l_sWhere Varchar2(2000);
  l_sValue Varchar2(2000);
  ls_gcode Varchar2(2000);
  ls_gcode_chk Varchar2(2000);
  v_gcode_code Varchar2(2000);
  v_gcode_chk Varchar2(2000);
  l_sql Varchar2(2000);
  l_sql_temp Varchar2(2000);
  l_conf_type Varchar2(20);
  lt_where ENJOY_OTHERSREP.TT_WHERE;
  i Integer :=1;
  j Integer;
  C_rep   SYS_REFCURSOR;
begin
--   SET NOCOUNT ON;
  l_sWhere := in_sWhere;
  l_sValue := in_sValue;
  -- 循环依次取where条件字段和条件值,存到自增长表:lt_where
  While instr(l_sWhere,';') > 0 Loop
     lt_where(i).F_COL := substr(l_sWhere,1,instr(l_sWhere,';')-1);
     lt_where(i).F_VAL := substr(l_sValue,1,instr(l_sValue,';')-1);
     If lt_where(i).F_COL = 'C_GCODE' Then
        ls_gcode := lt_where(i).F_VAL;
     Elsif lt_where(i).F_COL = 'C_CONF_TYPE' Then
        l_conf_type := lt_where(i).F_VAL;
     Elsif lt_where(i).F_COL = 'C_IST30' Then
        ls_gcode_chk := lt_where(i).F_VAL;
     End If;
     i := i + 1;
     -- 去掉取过的字段
     l_sWhere := substr(l_sWhere,instr(l_sWhere,';')+1);
     l_sValue := substr(l_sValue,instr(l_sValue,';')+1);
  End Loop;
  lt_where(i).F_COL := l_sWhere;
  lt_where(i).F_VAL := l_sValue;
  l_sql := 'update md_t30_list set C_IST30 = ''#ls_gcode_chk#'' where c_conf_type = '''||l_conf_type||'''';
  FOR j In 1 .. i Loop
     If lt_where(j).F_COL = 'C_STORE_AREA' And l_conf_type = '02' --区域
        Or lt_where(j).F_COL = 'C_STORE_ID' And l_conf_type In ('03','08','09','10','11') --门店
        Or lt_where(j).F_COL = 'C_SADNO' And l_conf_type In ('04','08')  --S部门
        Or lt_where(j).F_COL = 'C_SADNO' And l_conf_type In ('05','09')  --部门
        Or lt_where(j).F_COL = 'C_SADNO' And l_conf_type In ('06','10')  --部类
        Or lt_where(j).F_COL = 'C_SADNO' And l_conf_type In ('07','11') Then  --课类
        l_sWhere := l_sWhere||';'||lt_where(j).F_COL;
        l_sValue := l_sValue||';'||lt_where(j).F_VAL;
        l_sql := l_sql||' and '||lt_where(j).F_COL||' = '''||lt_where(j).F_VAL||'''';
     End If;
  End Loop;
  l_sql := l_sql ||' and c_gcode = ''#ls_gcode_code#''';
  While instr(ls_gcode,',') > 0 Loop
     v_gcode_code := substr(ls_gcode,1,instr(ls_gcode,';')-1);
     v_gcode_chk := substr(ls_gcode_chk,1,instr(ls_gcode_chk,';')-1);
     l_sql_temp := Replace(l_sql,'#ls_gcode_chk#',v_gcode_chk);
     l_sql_temp := Replace(l_sql_temp,'#ls_gcode_code#',v_gcode_code);
     Execute Immediate l_sql_temp;
     -- 去掉取过的字段
     ls_gcode := substr(ls_gcode,instr(ls_gcode,',')+1);
     ls_gcode_chk := substr(ls_gcode_chk,instr(ls_gcode_chk,',')+1);
  End Loop;
  l_sql_temp := Replace(l_sql,'#ls_gcode_chk#',ls_gcode_chk);
  l_sql_temp := Replace(l_sql_temp,'#ls_gcode_code#',ls_gcode);
  OPEN C_rep FOR 'select 1 rtn from dual';
  out_rep := C_rep;
  Commit;
Exception When Others Then
  OPEN C_rep FOR 'select -1 rtn from dual';
  out_rep := C_rep;
end sp_upt_t30check;
FineReport beluga 发布于 2022-4-18 13:48 (编辑于 2022-4-18 17:23)
悬赏:20 F币 4人赏过 + 添加悬赏
belugaLv6初级互助
发布于2022-8-2 10:31
表名给错了
  • 0关注人数
  • 509浏览人数
  • 最后回答于:2022-8-2 10:31
