oracle连不上
java.io.InvalidClassException: oracle.net.ns.NetException; local class incompatible: stream classdesc serialVersionUID = 4106461924854839888, local class serialVersionUID = 671241126795235024
java.io.ObjectStreamClass.initNonProxy(ObjectStreamClass.java.699)
java.io.ObjectInputStream.readNonProxyDesc(ObjectInputStream.java.1884)
java.io.ObjectInputStream.readClassDesc(ObjectInputStream.java.1750)
java.io.ObjectInputStream.readOrdinaryObject(ObjectInputStream.java.2041)
java.io.ObjectInputStream.readObject0(ObjectInputStream.java.1572)
java.io.ObjectInputStream.defaultReadFields(ObjectInputStream.java.2286)
java.io.ObjectInputStream.defaultReadObject(ObjectInputStream.java.560)
java.lang.Throwable.readObject(Throwable.java.914)
sun.reflect.NativeMethodAccessorImpl.invoke0(NativeMethodAccessorImpl.java.-2)
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java.62)
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java.43)
java.lang.reflect.Method.invoke(Method.java.498)
java.io.ObjectStreamClass.invokeReadObject(ObjectStreamClass.java.1170)
java.io.ObjectInputStream.readSerialData(ObjectInputStream.java.2177)
java.io.ObjectInputStream.readOrdinaryObject(ObjectInputStream.java.2068)
java.io.ObjectInputStream.readSerialData(ObjectInputStream.java.2210)
java.io.ObjectInputStream.readObject(ObjectInputStream.java.430)
com.fr.rpc.serialization.ResultSerializer.deserialize(null.-1)
com.fr.serialization.GZipSerializerWrapper.deserialize(null.-1)
com.fr.serialization.SerializerHelper.deserialize(null.-1)
com.fr.workspace.engine.rpc.WorkspaceInvoker.invoke(null.-1)
com.fr.workspace.engine.rpc.WorkspaceProxyPool$1.invoke(null.-1)
com.sun.proxy.$Proxy67.testConnectionWithException(null.-1)
com.fr.design.data.datapane.connect.DatabaseConnectionPane$1$1.doInBackground(null.-1)
javax.swing.SwingWorker$1.call(SwingWorker.java.295)
java.util.concurrent.FutureTask.run(FutureTask.java.266)
javax.swing.SwingWorker.run(SwingWorker.java.334)
java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java.1149)
java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java.624)
java.lang.Thread.run(Thread.java.748)
显示这个报错
FineReport callie 发布于 2022-4-24 10:33 (编辑于 2022-4-24 10:33)
用户6NWif5139660Lv6资深互助
发布于2022-4-24 10:33(编辑于 2022-4-24 10:34)
看下驱动是不是有问题
参考oracle连接常见错误-https://help.fanruan.com/finereport/doc-view-3714.html
  • 372浏览人数
  • 最后回答于:2022-4-24 10:34
