FineBI连接SAPhana数据库,测试连接失败
com.fr.third.alibaba.druid.pool.GetConnectionTimeoutException: wait millis 10057, active 0, maxActive 80, creating 0, createErrorCount 6 at com.fr.third.alibaba.druid.pool.DruidDataSource.getConnectionInternal(DruidDataSource.java:1831) at com.fr.third.alibaba.druid.pool.DruidDataSource.getConnectionDirect(DruidDataSource.java:1481) at com.fr.third.alibaba.druid.pool.DruidDataSource.getConnection(DruidDataSource.java:1461) at com.fr.third.alibaba.druid.pool.DruidDataSource.getConnection(DruidDataSource.java:1450) at com.fr.third.alibaba.druid.pool.DruidDataSource.getConnection(DruidDataSource.java:100) at com.fr.stable.pool.DataSourceWrapper.getConnection(Unknown Source) at com.fr.data.pool.MemoryConnection.create(Unknown Source) at com.fr.data.auth.Authentication.authenticate(Unknown Source) at com.fr.data.impl.JDBCDatabaseConnection.createConnection(Unknown Source) at com.fr.data.impl.JDBCDatabaseConnection.testConnection(Unknown Source) at com.fr.decision.webservice.v10.datasource.connection.processor.impl.JDBCConnectionProcessor.testConnection(Unknown Source) at com.fr.decision.webservice.v10.datasource.connection.processor.impl.ConnectionProcessorFactory.testConnectionWithSchemaReturn(Unknown Source) at com.fr.decision.webservice.v10.datasource.connection.ConnectionService.testConnection(Unknown Source) at sun.reflect.GeneratedMethodAccessor502.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:498) at com.fr.decision.config.ConfigInterceptor.intercept(Unknown Source) at com.fr.decision.webservice.v10.datasource.connection.ConnectionService$$EnhancerByCGLIB$$a4fd73f2.testConnection(
FineBI yzmN8MrG8989746 发布于 2022-4-26 14:45 (编辑于 2022-4-26 14:47)
发布于2022-4-26 14:48
SAP HANA数据连接-https://help.fanruan.com/finebi/doc-view-306.html
看看驱动版本对不对
  • yzmN8MrG8989746 yzmN8MrG8989746(提问者) 已经添加了这个驱动,测试依然失败
    2022-04-26 14:52
  • snrtuemc snrtuemc 回复 yzmN8MrG8989746(提问者) 要看你hana是不是这个版本,不是的话,这个驱动无效的
    2022-04-26 14:53
  • yzmN8MrG8989746 yzmN8MrG8989746(提问者) 回复 snrtuemc hana2.0版本的应该用哪个驱动呢?
    2022-04-26 15:38
  • snrtuemc snrtuemc 回复 yzmN8MrG8989746(提问者) 去hana官网看看有没有对应jdbc驱动
    2022-04-26 18:41
  • lqyfbl lqyfbl 回复 yzmN8MrG8989746(提问者) 朋友这个问题你解决了吗,我也是这个问题
    2022-07-23 09:05
  • 251浏览人数
  • 最后回答于:2022-4-26 14:48
