求帮忙改一句SQL
select c.ITEM供应商合并, c.ITEM, c.物料说明, c.SQE, c.供应商, c.PO,c.time
      from (select *
            from dbo.活动区间ITEM a
            where convert(varchar(10), time, 120) >= '${p3}'
              and convert(varchar(10), time, 120) <= '${p4}'
              and a.ITEM in (select ITEM
                             from dbo.活动区间ITEM
                             where convert(varchar(10), time, 120) >= '${p1}'
                               and convert(varchar(10), time, 120) <= '${p2}'
${if(p5="全部","",if(p5="其他","and left(ITEM,2) NOT IN ('AA' ,'AB', 'AC' ,'AD','AE')","and left(ITEM,2)='"+p5+"'"))})
${if(p5="全部","",if(p5="其他","and left(ITEM,2) NOT IN ('AA' ,'AB', 'AC' ,'AD','AE')","and left(ITEM,2)='"+p5+"'"))}${if(SQE="全部","","and SQE ='"+SQE+"'")}) c
      where c.ITEM供应商合并 not in (select 活动区间ITEM.ITEM供应商合并
                                from dbo.活动区间ITEM
                                  and convert(varchar(10), time, 120) <= '${p2}')
      group by c.ITEM供应商合并, c.ITEM, c.物料说明, c.SQE, c.供应商, c.PO,c.time
需要新增一列优选供应商 从dbo.活动区间ITEM里查询 原来的意思是区分这个ITEM之前存在的 现在供应商不同了 现在同时需要查到原来的供应商 条件是convert(varchar(10), time, 120) = '2021-12-31'
sqlserver服务器请问怎么修改
callie 发布于 2022-5-15 13:23 (编辑于 2022-5-15 18:50)
悬赏:5 F币 4人赏过 + 添加悬赏
callieLv4见习互助
发布于2022-5-16 10:20
select aa.*, bb.供应商 as 优选供应商
from (select c.ITEM供应商合并
           , c.ITEM
           , c.物料说明
           , c.SQE
           , c.供应商
           , c.PO
           , c.time
      from (select *
            from dbo.活动区间ITEM a
            where convert(varchar(10), time, 120) >= '2022-01-01'
              and convert(varchar(10), time, 120) <= '2022-05-16'
                             from dbo.活动区间ITEM
                             where convert(varchar(10), time, 120) >= '2021-01-01'
                               and convert(varchar(10), time, 120) <= '2021-12-31'
           ) c
                                from dbo.活动区间ITEM
                                  and convert(varchar(10), time, 120) <= '2021-12-31')) aa
         left join (select ITEM, a.供应商
                    from dbo.活动区间ITEM a
                      and convert(varchar(10), time, 120) <= '2021-12-31') bb on aa.ITEM = bb.ITEM;
用户a8068717Lv4初级互助
发布于2022-5-15 13:35(编辑于 2022-5-15 13:38)
with a (
      ,case when convert(varchar(10), c.time, 120) = '2021-12-31' then c.供应商 end as 优选供应商
  from (select *
            from dbo.活动区间ITEM a
                             from dbo.活动区间ITEM
                                from dbo.活动区间ITEM
select ITEM供应商合并, ITEM, 物料说明, SQE, 供应商, PO,time,优选供应商
from a
      group by ITEM供应商合并, ITEM, 物料说明, SQE, 供应商, PO,time,优选供应商
  • callie callie(提问者) 显示select附近有语法错误
    2022-05-15 13:51
  • 用户a8068717 用户a8068717 回复 callie(提问者) 没看到你已经有a了,把我的a 改成其它,比如d
    2022-05-15 14:17
  • callie callie(提问者) 回复 用户a8068717 是SQLSERVER的服务器 改成D了还是现实select附近有语法错误报错
    2022-05-15 18:27
  • 用户a8068717 用户a8068717 回复 callie(提问者) 不好意思,少了一个as,with d as (
    2022-05-15 19:18
  • callie callie(提问者) 回复 用户a8068717 确实是没有报错了 但是结果不是我想要的 你写的意思应该是把时间是12-31的变成优选供应商吧 我想要的是查到原来的优选供应商在P1P2范围里面的
    2022-05-16 09:08
fiskerLv4见习互助
发布于2022-5-15 13:46
where后边的条件放在select中可以提高查询效率
  • 489浏览人数
  • 最后回答于:2022-5-16 10:20
