请问为什么这里会报错
SELECT
a.mpay_type_txt,a.银联卡日支付, b.银联卡月支付, c.银联卡年支付
FROM
(select mpay_type_txt, sum(amount)/10000 as '银联卡日支付' from
lsyw_yp_payinfo_d_hy group by mpay_type_txt
where calday =translate(substr(date_sub(CURRENT_DATE(),1) , 1 ,10 ),'-','') and mpay_type_txt="银联卡"
)a
full join
from
(select mpay_type_txt, sum(amount)/10000 as '银联卡月支付' from
lsyw_yp_payinfo_hy group by mpay_type_txt
where calmonth =translate(substr(date_sub(CURRENT_DATE(),1) , 1 ,7 ),'-','') and mpay_type_txt="银联卡"
)b
on a.mpay_type_txt = b.mpay_type_txt
full join
(select mpay_type_txt, sum(amount)/10000 as '银联卡年支付' from
where calday =translate(substr(date_sub(CURRENT_DATE(),1) , 1 ,4 ),'-','') and mpay_type_txt="银联卡"
)c
on a.mpay_type_txt =c.mpay_type_txt
FineReport 用户x076327 发布于 2022-5-18 09:25
重庆一棵草Lv4中级互助
发布于2022-5-18 09:40
  • 225浏览人数
  • 最后回答于:2022-5-18 09:40
