function() { var point = this; var series = this.series; var points = this.points;/*获取当前分类下所有点*/ var validPoints = points.filter(function(p) { return p.series.visible && p.visible && !p.isNull;/*获取当前分类下的有效点*/ }); var len = points.length; var vlen = validPoints.length; if (point == validPoints[vlen - 1]) { var value = 0; for (var i = -1; ++i < len;) { if (points[i].series.visible) { value += points[i].getTargetValue();/*获取点的值*/ } } return value.toFixed(0)+""+this.value.toFixed(0);/*返回相加后的值*/ } else { return this.value.toFixed(0);/*返回各个系列的值*/ } } |
最佳回答 |
