优化sql语句
SELECT h.customer_po_number --客户PO
      ,h.order_number --订单编号
      ,h.order_type_name --订单类型
      ,h.suit_count --套数
      ,h.order_status_name --状态
      ,to_char(h.booked_date,'yyyy-mm-dd') booked_date--订单受理日期
      ,to_char(h.delivery_date,'yyyy-mm-dd') delivery_date --订单发货日期
      ,to_char(h.creation_date,'yyyy-mm-dd') creation_date  --订单创建日期
      ,to_char(h.complete_date,'yyyy-mm-dd') complete_date  --订单完工日期
      ,h.zq --战区
      ,h.sq --省区
      ,h.pq --片区
      ,h.city --城市
    /*  ,h.segment1
      ,h.segment2
      ,h.segment3*/
      ,h.account_number --客户编码
      ,h.account_short_name --客户简称
         ,h.promotion_name --活动
      ,h.style_series --风格系列
  ,ooh.order_progress as 进展
    --,hfv.confirmed_name as 核价员
    ,oe.design_method as 设计方式
    ,oe.end_cust_name -- 终端客户地址
    ,oe.end_cust_phone -- 终端客户电话
     ,oe.end_cust_address -- 终端客户地址
    ,SUM(decode(l.item_class,'MM',nvl(l.yg_order_amount ,0) - nvl(l.charge_amount ,0),0)) AS mm --木门
    ,SUM(decode(l.item_class,'LKM',nvl(l.yg_order_amount ,0) - nvl(l.charge_amount ,0),0)) AS LKM--铝框门款
      ,SUM(decode(l.item_class,'QB',nvl(l.yg_order_amount ,0) - nvl(l.charge_amount ,0),0)) AS QB --墙板款
    ,SUM(decode(l.item_class,'MMYB',nvl(l.yg_order_amount ,0) - nvl(l.charge_amount ,0),0)) AS MMYB --岩板款
    ,SUM(decode(l.item_class,'PTCP',nvl(l.yg_order_amount ,0) - nvl(l.charge_amount ,0),0)) AS PTCP-- 配套款
    ,SUM(decode(l.item_class,'WJPJ',nvl(l.yg_order_amount ,0) - nvl(l.charge_amount ,0),0)) AS WJPJ-- 五金配件款
      ,SUM(decode(l.item_class,'CPJJ',nvl(l.yg_order_amount ,0) - nvl(l.charge_amount ,0),0)) AS CPJJ-- 成品家居款6
     , SUM(decode(l.item_class,'YYWPM',nvl(l.yg_order_amount ,0) - nvl(l.charge_amount ,0),0)) AS YYWPM-- 运动款
    ,SUM(decode(l.item_class,'MMSP',nvl(l.yg_order_amount ,0) - nvl(l.charge_amount ,0),0)) AS MMSP -- 饰品款
  ,SUM(CASE WHEN l.item_class NOT IN
                  ('MM','LKM','QB', 'MMYB','PTCP','WJPJ','CPJJ', 'YYWPM','MMSP' ) THEN
               nvl(l.yg_order_amount, 0) - nvl(l.charge_amount, 0)
             ELSE
              0  END ) AS qy
       FROM apps.cux_om_order_headers_v h
      ,apps.cux_om_order_lines_v   l
  ,mdm_cust_finerpt_user_access fu
  ,oms_oe_order_types       ooot
       ,oms_oe_order_headers ooh --添加进展
         --,APPS.OMS_OE_ORDER_HEADER_FINE_V hfv--添加核价员
          ,oms_oe_order_header_atts oe --添加终端
      WHERE
       h.header_id = l.header_id and l.header_id=ooh.header_id
       and ooh.header_id=oe.header_id
       --and oe.header_id =hfv.header_id
       AND h.order_type_id = ooot.order_type_id and ooot.order_type_id=ooh.order_type_id (+)
       --AND ooot.LEFT_FLAG = 'N' --是否遗留单:Y:是,N:否
       AND ooot.CHANGE_FLAG = 'N'--是否更改单:Y:是,N:否
       AND   h.unit_code =161
       AND FU.ORG_ID=H.unit_code
${if(len(BookDates)=0,"","and h.booked_date>=to_date('"+BookDates+"','yyyy-mm-dd')")}
${if(len(BookDatee)=0,"","and h.booked_date<to_date('"+BookDatee+"','yyyy-mm-dd')+1")}
${if(len(BookDates_c)=0,"","and h.creation_date>=to_date('"+BookDates_c+"','yyyy-mm-dd')")}
${if(len(BookDatee_c)=0,"","and h.creation_date<to_date('"+BookDatee_c+"','yyyy-mm-dd')+1")}
 ${if(len(sq)==0,"", "and h.sq in ('" + replace(sq,",","','") + "')")}
 ${if(len(po) == 0,"","and  h.customer_po_number  like '%"+po+"%'")}
 --添加订单类型过滤
  ${if(len(订单类型)==0,"","and h.order_type_name like '%"+订单类型+"%'")}
  --添加客户简称过滤
  ${if(len(客户简称)==0,"","and h.account_short_name like '%"+客户简称+"%'")}
--添加订单编号过滤
  ${if(len(订单编号)==0,"","and h.order_number  like '%"+订单编号+"%'")}
 AND h.order_type_name not  like '%遗留%'
 AND h.order_type_name not  like '%厂部%'
 AND h.order_type_name not  like '%运营物品%'
 AND h.header_id = l.header_id
--AND (fu.is_qd='N' OR fu.is_qd='A' OR h.site_code='1' )
GROUP BY
      ,h.suit_count --套数
      ,to_char(h.creation_date,'yyyy-mm-dd') --订单创建日期
      ,to_char(h.booked_date,'yyyy-mm-dd') --订单受理日期
      ,to_char(h.complete_date,'yyyy-mm-dd')  --订单完工日期
      ,to_char(h.delivery_date,'yyyy-mm-dd')  --订单发货日期
      ,h.zq --战区
      ,h.sq --省区
      ,h.pq --片区
      ,h.city --城市
      ,ooh.order_progress   --进展
       --,hfv.confirmed_name -- 核价员
       ,oe.design_method --设计方式
我这个代加载的好慢,是SQL、语句的问题还是服务器卡?
FineReport 艾琳c 发布于 2022-5-27 10:08
共5回答
发布于2022-5-27 10:11(编辑于 2022-5-27 10:14)
慢:mdm_cust_finerpt_user_access fu   这个表你添加了后,没有关联条件。这样就直接产生了笛卡尔的积了。如果这个表的数据量多。那么不管你是什么服务器。和数据库。它都不可能快
还有我看你apps.cux_om_order_headers_v与cux_om_order_lines_v像是视图。没有索引吧。这样也会慢。。。
删除这张表mdm_cust_finerpt_user_access,,我看你根本就没有使用这张表。也没有显示这张表的什么字段,直接删除掉它。。再看
  • 艾琳c 艾琳c(提问者) fu关联了:FU.ORG_ID=H.unit_code
    2022-05-27 10:13
  • 艾琳c 艾琳c(提问者) 是视图
    2022-05-27 10:13
  • CD20160914 CD20160914 回复 艾琳c(提问者) 你关联个鬼哟。。你自己把它注释了呀。。。你自己看
    2022-05-27 10:15
  • 艾琳c 艾琳c(提问者) 回复 CD20160914 AND FU.ORG_ID=H.unit_code这个没有注释哟
    2022-05-27 10:19
  • CD20160914 CD20160914 回复 艾琳c(提问者) 你发的语句,你自己看你写了注释的。。如果你在你的电脑上没有注释。那么你自己检查一下两个视图的数据量大概分别是多少行吧。视图也可以创建索引。。。你先创建索引吧。。你关联的字段创建索引
    2022-05-27 10:22
发布于2022-5-27 10:09
好长...........
重庆一棵草Lv4中级互助
发布于2022-5-27 10:10
数据量大不大哟。
qiqits1984Lv6中级互助
发布于2022-5-27 10:14
什么类型的数据库?sql server ?可以增加数据库的内存。
语句可不可以把sum 单独计算后,再与数据关联,能不能快点也是不清楚。
坚果联盟Lv5见习互助
发布于2022-5-27 11:38
where后面like太多了,select后面还有很多sum和计算公式,这些都会增加查询速度
  • 6关注人数
  • 477浏览人数
  • 最后回答于:2022-5-27 11:38
