只要求前两个语句加这个条件,后两个不加
${if(len(BookDates)=0,"","and res.START_DATE>=to_date('"+BookDates+"','yyyy-mm-dd') and res.high_version='Y'")}
${if(len(BookDates)=0,"","and res.START_DATE<=to_date('"+BookDatee+"','yyyy-mm-dd')and res.high_version='Y'")}
${if(len(BookDates_c)=0,"","and res.PZ_DATE>=to_date('"+BookDates_c+"','yyyy-mm-dd')")}
${if(len(BookDates_c)=0,"","and res.PZ_DATE<=to_date('"+BookDatee_c+"','yyyy-mm-dd')")}
FineReport 帆软用户XpbwOTiAvi 发布于 2022-6-7 16:07 (编辑于 2022-6-7 16:16)
发布于2022-6-7 16:17(编辑于 2022-6-7 16:17)
where 1=1
${if(len(BookDates)=0,"and res.high_version='Y'","and res.START_DATE>=to_date('"+BookDates+"','yyyy-mm-dd') and res.high_version='Y'")}
发布于2022-6-7 16:08
可以的啊
发布于2022-6-7 16:08(编辑于 2022-6-7 16:12)
你这个只有在BookDates不为空是才会加
andres.high_version='Y’
如果是你场景需要的就没问题
SELECT * FROM TABLE WHERE res.high_version='Y' ${if(len(BookDates)=0,"","and res.START_DATE>=to_date('"+BookDates+"','yyyy-mm-dd') ")}
  • 252浏览人数
  • 最后回答于:2022-6-7 16:17
