查询语句优化,现在遇到一个问题,语句我认为已经很简单了,但查询数据量大的时候还是很慢
查询语句优化,现在遇到一个问题,语句我认为已经很简单了,但查询数据量大的时候还是很慢,即使我只选择了时间范围查询(比如去年到今天一年),其他控件都是空白的。
SELECT
a.product_no,
a.batch_number,
a.busi_type,
a.furnace_no,
a.matrial_gz,
a.inv_gz,
a.inv_model,
a.define01,
a.executive_standard,
a.num,
a.update_date,
a.theory_weight,
a.inv_name,
a.define05,
a.define08,
a.remain_num,
a.define15,
a.icheck,
a.define06,
a.define07,
a.inv_code,
a.define09,
a.define10,
a.ware_name,
a.define02,
a.define03,
a.define13,
a.define14,
a.create_date,
a.check_time,
a.location_name,
a.define22,
c.realname AS check_name ,
d.realname as  create_name,
CASE
          WHEN a.remain_num = '0'   AND a.busi_type<>'OutInvol'
          THEN  '出库'
          WHEN a.remain_num > '0'  AND a.busi_type<>'OutInvol'
          THEN  '库存'
          ELSE '内盘出库'
        END  AS  zt
FROM pd_store_record a
LEFT JOIN sys_user c ON a.`check_user_id`=c.`id`
LEFT JOIN sys_user d ON a.`create_user_id`=d.`id`
WHERE  a.busi_type <> 'OutStock' AND  a.ideleted=0 and
a.create_date BETWEEN  '${startTime}' AND '${endTime}'
${if(kczt==1," and   a.remain_num > '0'  and   a.busi_type<>'OutInvol'","")}
     ${if(kczt==2," and   a.remain_num = '0'  and   a.busi_type<>'OutInvol'","")}
     ${if(kczt==3,"and a.busi_type='OutInvol'","")}
${if(len(icheck) == 0,"","and a.icheck='"+icheck+"'")}
${if(len(ck)==0,"","and a.ware_name='"+ck+"'")}
${if(len(inv_model) == 0,"","and a.inv_model like '%" + inv_model + "%'" )}
${if(len(define13) == 0,"","and a.define13 like '%" + define13 + "%'" )}
${if(len(define22) == 0,"","and a.define05 like '%" + define22 + "%'" )}
     ${if(len(TEXTT) == 0,"","and a.define22 like '%" + TEXTT + "%'" )}
${if(len(product_no) == 0,"","and a.product_no like '%" + product_no + "%'" )}
${if(len(define0222) == 0,"","and a.define02 in ('" + define0222 + "')")}
${if(len(furnace_no) == 0,"","and a.furnace_no like '%" + furnace_no + "%'" )}
${if(len(batch_number) == 0,"","and a.batch_number like '%" + batch_number + "%'" )}
${if(len(define03) == 0,"","and a.define03=  '" + define03 + "'" )}
${if(len(define01) == 0,"","and a.define01 like '" + define01 + "'" )}
${if(len(inv_gz) == 0,"","and a.inv_gz like '%" + inv_gz + "%'" )}
${if(len(executive_standard) == 0,"","and a.executive_standard like '%" + executive_standard + "%'" )}
${if(len(define07) == 0,"","and a.define07='"+define07+"'")}
${if(len(matrial_gz) == 0,"","and a.matrial_gz= '" + matrial_gz + "'" )}
张三学帆软 发布于 2022-6-8 11:38 (编辑于 2022-6-8 11:39)
发布于2022-6-8 11:40
直接在你的数据库管理工具里面查询速度咋样?
FuFuLv5初级互助
发布于2022-6-8 11:39
小表关联大表
  • 370浏览人数
  • 最后回答于:2022-6-8 11:40
