麻烦帮我看看这个错在哪里,可以这样用吗?提示我报错。
FineReport 用户jGnXs7014103 发布于 2022-6-10 11:22 (编辑于 2022-6-10 11:35)
发布于2022-6-10 11:28(编辑于 2022-6-10 11:35)
你的sql肯定有问题,${}中还有${}
你把语句拷贝出来,帮你改。。。。
${if(SFJM='全量', "select * from View_ZJGD_GXBZ_ONLY where cast([boss归档时间] as date)>='"+time+"' and cast([boss归档时间] as date)<='"+time_c+"' and [是否是校园宽带] like '%否%'", "select a.* from View_ZJGD_GXBZ_ONLY as a left join (select 工单编码 from ZJJM where cast(减免时间 as date) like left('"+time+"',7) + '%') as b on a.工单编码=b.工单编码 where b.工单编码 is null and cast([boss归档时间] as date)>='"+time+"' and cast([boss归档时间] as date)<='"+time_c+" and [是否是校园宽带] like '%否%' ")}
  • 用户jGnXs7014103 用户jGnXs7014103(提问者) ${if(${SFJM}=\'全量\', select * from View_ZJGD_GXBZ_ONLY where cast([boss归档时间] as date)>=\'${time}\' and cast([boss归档时间] as date)<=\'${time_c}\' and [是否是校园宽带] like \'%否%\', select a.* from View_ZJGD_GXBZ_ONLY as a left join (select 工单编码 from ZJJM where cast(减免时间 as date) like left(\'${time}\',7) + \'%\') as b on a.工单编码=b.工单编码 where b.工单编码 is null and cast([boss归档时间] as date)>=\'${time}\' and cast([boss归档时间] as date)<=\'${time_c}\' and [是否是校园宽带] like \'%否%\' )}
    2022-06-10 11:30
  • snrtuemc snrtuemc 回复 用户jGnXs7014103(提问者) 看修改答案
    2022-06-10 11:36
重庆一棵草Lv4中级互助
发布于2022-6-10 11:23
宝杀错?
  • 用户jGnXs7014103 用户jGnXs7014103(提问者) 错误代码:11300001 数据集配置错误
    Query:
    com.microsoft.sqlserver.jdbc.SQLServerException: “$”附近有语法错误。
    2022-06-10 11:26
发布于2022-6-10 11:28(编辑于 2022-6-10 12:25)
${if(SFJM='全量',"
"select a.* from View_ZJGD_GXBZ_ONLY as a left join (select 工单编码 from ZJJM where cast(减免时间 as date) like '"+left(time,7)+"%') as b on a.工单编码=b.工单编码
where b.工单编码 is null and cast([boss归档时间] as date)>='"+time+"' and cast([boss归档时间] as date)<='"+time_c+"' and [是否是校园宽带] like '%否%'"
  • 用户jGnXs7014103 用户jGnXs7014103(提问者) 这样也不行
    2022-06-10 11:31
  • CD20160914 CD20160914 回复 用户jGnXs7014103(提问者) 看我最新修改的。。我看出来的语法是没有问题的了
    2022-06-10 12:22
  • 358浏览人数
  • 最后回答于:2022-6-10 12:25
