yzmXrTpA3762457(提问者)${if(fine_role!=\"催收员\",\"\",if(fine_role=\"数据员\",\"and t.typ_name in \'\"+SELECT DISTINCT REPLACE( REPLACE( b.typ_name, \'YC\', \'\' ), \' \', \'\' ) AS area_name FROM bank_case a JOIN type_list b ON a.cas_cl_area_id = b.typ_id WHERE a.cas_name = \'胥兰\'+\"\'\",\"\"))}
Z4u3z1 回复 yzmXrTpA3762457(提问者)${if(fine_role!=\"催收员\",\"\",if(fine_role=\"数据员\",\"and t.typ_name in (SELECT DISTINCT REPLACE( REPLACE( b.typ_name, \'YC\', \'\' ), \' \', \'\' ) AS area_name FROM bank_case a JOIN type_list b ON a.cas_cl_area_id = b.typ_id WHERE a.cas_name = \'胥兰\')\",\"\"))}
