js实现批量打印一直报错500,是什么原因呢
var printurl="http://192.168.0.165:37799/webroot/decision/view/report";
var run_ids = [];
var paths = [];
var singlepaths = [];
var $span = $('.fr-checkbox-checkon');
var $tds = $("td").has($span);
var $trs = $("tr").has($tds);
var p=[];
if($trs.length==0){
 alert('勾选项不可全为空!');//未选中时不可打印
else
for(var i=0; i<$trs.length;i++){
 var run_id = $("td:eq(0)",$($trs[i])).html();
 var cptpath ="鼎捷E10/领料单明细1.cpt";
 var urlstring = "{reportlet:" + "'" + cptpath + "'" + ",item_no:" +"'"+ run_id +"'}";
 debugger;
 paths.push(urlstring);
 debugger;
if(paths.length>0){
 var rpaths=paths.join(",");
 var reportlets="["+rpaths+"]";
 var config = {
   printUrl : printurl,
   printType : 0,
   isPopUp : false,
   data : {reportlets:reportlets}
debugger;
FR.doURLPrint(config);
FineReport 百煮味香 发布于 2022-7-4 16:10
发布于2022-11-15 17:19
批量打印-https://help.fanruan.com/finereport/doc-view-1095.html
  • 333浏览人数
  • 最后回答于:2022-11-15 17:19
