SQLserver分组排序
yzm233020 发布于 2022-7-13 14:08
发布于2022-7-13 14:11(编辑于 2022-7-13 14:42)
先排序 在string_agg
-------参考
SET NOCOUNT ON
IF OBJECT_ID('TEMPDB..#TestTable') IS NOT NULL DROP TABLE #TestTable
CREATE TABLE #TestTable(
[A] [nvarchar](30) NULL,
[B] [nvarchar](30) NULL
with a as (
select '1' [a],'1吨' [B] union all
select '1' [a],'50米' [B] union all
select '1' [a],'4只' [B] union all
select '2' [a],'50米' [B] union all
select '2' [a],'10吨' [B] union all
select '2' [a],'4只' [B] union all
select '3' [a],'4只' [B] union all
select '3' [a],'1吨' [B] union all
select '3' [a],'50米' [B] union all
select '4' [a],'50米' [B] union all
select '4' [a],'4只' [B] union all
select '4' [a],'1吨' [B]
INSERT INTO #TestTable
SELECT * FROM A  ORDER BY A,(CASE WHEN B LIKE '%吨%' THEN 1 WHEN B LIKE '%米%' THEN 2  ELSE 3 END) asc
SELECT A,STRING_AGG(B,',') FROM #TestTable GROUP BY A
发布于2022-7-13 14:13
你拼好后,还要单独列出吨前面的数字?就比如第一行   323.00吨XXXX内容   你还要一个单独是323的结果?
  • 312浏览人数
  • 最后回答于:2022-7-13 14:42
