Excel提交后执行mergeinto函数的SQL语句
Excel提交后执行以下mergeinto函数的SQL语句
merge into table1
using  (select t.idd ,max(t.val) m from table2 t group by t.idd)table2
on (table1.idd = table2.idd)
when matched then
update set table1.val = table2.m
FineReport UYoHIZgn 发布于 2022-8-8 17:31 (编辑于 2022-8-8 17:33)
听雨轩Lv6初级互助
发布于2022-8-8 17:47(编辑于 2022-8-8 17:51)
如此这般
var sql="merge into table1 using  (select t.idd ,max(t.val) m from table2 t group by t.idd)table2 on (table1.idd = table2.idd) when matched then update set table1.val = table2.m"
FR.remoteEvaluate('=SQL("自己的定义数据连接名","'+sql+'",1,1)');
  • 358浏览人数
  • 最后回答于:2022-8-8 17:51
