SQLserver数据库,用SQL语句查询,填充空值为最近的不为空的数据。底层表如左图,查询结果右图
铁骨铮铮 发布于 2022-8-9 17:11 (编辑于 2022-8-9 17:26)
悬赏:0 F币 + 添加悬赏
lxy2Lv6中级互助
发布于2022-8-9 17:32
with c as(
select *,
ROW_NUMBER()over(order by a asc) as xh
from (
select 1 a,2 as b
union all
select 2 a,null
union all
select 3 a,3
union all
select 4 a,null
union all
select 5 a,null
union all
select 6 a,7
) a
select isnull(b,(select top 1 b from c where not b is null and xh<a.xh order by xh desc )) as 新值,* from c as a
privacyLv5初级互助
发布于2022-8-9 17:31
用sql处理很麻烦的,还不如在页面处理;下面是页面处理的例子
发布于2022-8-9 17:35
with a as (
select '71' [id],20 [sl]
union all
select '72' [id],null [sl]
union all
select '73' [id],50 [sl]
union all
select '74' [id],null [sl]
union all
select '75' [id],10 [sl]
union all
select '76' [id],null [sl]
union all
select '77' [id],null [sl]
union all
select '78' [id],70 [sl]
SELECT *,(CASE WHEN SL IS NULL THEN (SELECT TOP 1 SL FROM A T WHERE T.ID<A.ID AND T.sl IS NOT NULL ORDER BY T.id DESC) ELSE SL END) FROM A
PS:还是送点分嘛
听雨轩Lv6初级互助
发布于2022-8-9 17:58
with temp1 as (
select 70 as a,20 as b
union all
select 71 as a,null as b
union all
select 72 as a,null as b
union all
select 73 as a,21 as b
union all
select 74 as a,null as b
union all
select 75 as a,null as b
union all
select 76 as a,32 as b
union all
select 77 as a,35 as b
 select a.*,coalesce (a.b,b.b)
 from temp1 a
 left join (
 select *
 from
  select a,b,lead (a)over() as lead_rn
   from temp1
  where b is not null
 )s
 where lead_rn is not null
 ) b
 on a.a >= b.a and a.a< b.lead_rn
  • 1003浏览人数
  • 最后回答于:2022-8-9 17:58
