平台备份报错
平台备份报错,看不太懂,有没有大佬帮忙指点下
java.lang.Exception: Fail to write entity Entity
        at com.fr.decision.backup.BackUpContext.write(BackUpContext.java:99)
        at com.fr.decision.backup.AbstractBackUpRecoveryContext.write(AbstractBackUpRecoveryContext.java:159)
        at com.fr.decision.backup.AbstractBackUpRecoveryContext.transfer(AbstractBackUpRecoveryContext.java:98)
        at com.fr.decision.backup.BackUpContext.backUp(BackUpContext.java:62)
        at com.fr.decision.webservice.v10.backup.module.BaseModuleBackup.backupDB(BaseModuleBackup.java:554)
        at com.fr.decision.webservice.v10.backup.module.ConfigBackup.extensionalBackup(ConfigBackup.java:29)
        at com.fr.decision.webservice.v10.backup.module.BaseModuleBackup.backup(BaseModuleBackup.java:201)
        at com.fr.decision.webservice.v10.backup.module.BaseModuleBackup.backup(BaseModuleBackup.java:135)
        at com.fr.decision.webservice.v10.backup.BackupModuleJob.doAutoBackup(BackupModuleJob.java:43)
        at com.fr.decision.webservice.v10.backup.BackupModuleJob.run(BackupModuleJob.java:34)
        at com.fr.scheduler.job.FineScheduleJob.execute(FineScheduleJob.java)
        at com.fr.third.v2.org.quartz.core.JobRunShell.run(JobRunShell.java:204)
        at com.fr.third.alibaba.ttl.TtlRunnable.run(TtlRunnable.java:58)
        at com.fr.third.v2.org.quartz.simpl.SimpleThreadPool$WorkerThread.run(SimpleThreadPool.java:606)
Caused by: com.fr.third.org.hibernate.exception.DataException: could not execute statement
        at com.fr.third.org.hibernate.exception.internal.SQLExceptionTypeDelegate.convert(SQLExceptionTypeDelegate.java:52)
        at com.fr.third.org.hibernate.exception.internal.StandardSQLExceptionConverter.convert(StandardSQLExceptionConverter.java:42)
        at com.fr.third.org.hibernate.engine.jdbc.spi.SqlExceptionHelper.convert(SqlExceptionHelper.java:111)
        at com.fr.third.org.hibernate.engine.jdbc.spi.SqlExceptionHelper.convert(SqlExceptionHelper.java:97)
        at com.fr.third.org.hibernate.engine.jdbc.internal.ResultSetReturnImpl.executeUpdate(ResultSetReturnImpl.java:207)
        at com.fr.third.org.hibernate.engine.jdbc.batch.internal.NonBatchingBatch.addToBatch(NonBatchingBatch.java:45)
        at com.fr.third.org.hibernate.persister.entity.AbstractEntityPersister.insert(AbstractEntityPersister.java:2997)
        at com.fr.third.org.hibernate.persister.entity.AbstractEntityPersister.insert(AbstractEntityPersister.java:3497)
        at com.fr.third.org.hibernate.action.internal.EntityInsertAction.execute(EntityInsertAction.java:89)
        at com.fr.third.org.hibernate.engine.spi.ActionQueue.executeActions(ActionQueue.java:588)
        at com.fr.third.org.hibernate.engine.spi.ActionQueue.executeActions(ActionQueue.java:462)
        at com.fr.third.org.hibernate.event.internal.AbstractFlushingEventListener.performExecutions(AbstractFlushingEventListener.java:337)
        at com.fr.third.org.hibernate.event.internal.DefaultFlushEventListener.onFlush(DefaultFlushEventListener.java:39)
        at com.fr.third.org.hibernate.internal.SessionImpl.flush(SessionImpl.java:1294)
        at com.fr.stable.db.session.SessionManager$DBSessionImpl.flush(SessionManager.java)
        at com.fr.decision.backup.BackUpContext.write(BackUpContext.java:90)
        ... 13 more
Caused by: java.sql.SQLDataException: data exception: string data, right truncation;  table: FINE_CONF_ENTITY column: VALUE
        at com.fr.third.org.hsqldb.jdbc.JDBCUtil.sqlException(JDBCUtil.java:322)
        at com.fr.third.org.hsqldb.jdbc.JDBCUtil.sqlException(JDBCUtil.java:247)
        at com.fr.third.org.hsqldb.jdbc.JDBCPreparedStatement.fetchResult(JDBCPreparedStatement.java:4675)
        at com.fr.third.org.hsqldb.jdbc.JDBCPreparedStatement.executeUpdate(JDBCPreparedStatement.java:312)
        at com.fr.third.alibaba.druid.pool.DruidPooledPreparedStatement.executeUpdate(DruidPooledPreparedStatement.java:255)
        at com.fr.third.org.hibernate.engine.jdbc.internal.ResultSetReturnImpl.executeUpdate(ResultSetReturnImpl.java:204)
        ... 24 more
Caused by: com.fr.third.org.hsqldb.HsqlException: data exception: string data, right truncation;  table: FINE_CONF_ENTITY column: VALUE
        at com.fr.third.org.hsqldb.error.Error.error(Error.java:138)
        at com.fr.third.org.hsqldb.Table.enforceTypeLimits(Table.java:2393)
        at com.fr.third.org.hsqldb.Table.generateAndCheckData(Table.java:2691)
        at com.fr.third.org.hsqldb.Table.insertSingleRow(Table.java:2705)
        at com.fr.third.org.hsqldb.StatementDML.insertSingleRow(StatementDML.java:969)
        at com.fr.third.org.hsqldb.StatementInsert.getResult(StatementInsert.java:153)
        at com.fr.third.org.hsqldb.StatementDMQL.execute(StatementDMQL.java:184)
        at com.fr.third.org.hsqldb.Session.executeCompiledStatement(Session.java:1384)
        at com.fr.third.org.hsqldb.Session.execute(Session.java:1007)
        at com.fr.third.org.hsqldb.jdbc.JDBCPreparedStatement.fetchResult(JDBCPreparedStatement.java:4667)
        ... 27 more
        at com.fr.third.org.hsqldb.error.Error.error(Error.java:107)
        at com.fr.third.org.hsqldb.types.CharacterType.convertToTypeLimits(CharacterType.java:443)
        at com.fr.third.org.hsqldb.Table.enforceTypeLimits(Table.java:2381)
        ... 35 more
FineReport 小白新手 发布于 2022-8-29 10:26
发布于2022-8-29 13:12
配置了MySQL外接数据库?将MySQL的引擎「MyISAM」切换为「InnoDB」后,重启服务再备份。
  • 小白新手 小白新手(提问者) 在那个里面可以调整这个?这个是有什么区别吗
    2022-08-29 13:37
  • zsh331 zsh331 回复 小白新手(提问者) 区别就是一个报错,一个不报表。具体原因,你们单位的dba应该懂!
    2022-08-29 13:38
  • 288浏览人数
  • 最后回答于:2022-8-29 13:12
