数据集if判断用那个sql,带参数
为啥里面加了一个if,外面这个参数就没有了,然后里面的if去掉,外面这个参数才能用
${if((OA='1'),"select *
       from newsoft_cs.oa_wt_temp tmp
left join newsoft_cs.oa_wt t on tmp.file_id = t.file_id
where t.status in ('S','A','ST') and
${if(len(zt) == 0,"","and t.status in ('" + zt + "')")}
${if(len(dybh) == 0,"","and tmp.print_code in ('" + dybh + "')")}
${if(len(sfz) == 0,"","and tmp.user_id in ('" + sfz + "')")}
${if(len(khmc) == 0,"","and tmp.customer_name in ('" + khmc + "')")}
${if(len(strxm) == 0,"","and tmp.user_name in ('" + strxm + "')")}
${if(len(stime) == 0,"","and tmp.begin_time >= ('" + stime + "')")}
${if(len(etime) == 0,"","and tmp.end_time < ('" + etime + "')")}
"select * from newsoft_cs.oa_wt_view
WHERE 1=1
FineReport 我在等风也等你 发布于 2022-9-2 09:05 (编辑于 2022-9-2 09:10)
发布于2022-9-2 09:08(编辑于 2022-9-2 09:16)
${}里面就能在${}了
语句拷贝出来,我给你改
${if(OA='1',"select * from newsoft_cs.oa_wt_temp tmp left join newsoft_cs.oa_wt t on tmp.file_id = t.file_id where t.status in ('S','A','ST')"+
if(len(zt) == 0,""," and t.status in ('" + zt + "')")+
if(len(dybh) == 0,""," and tmp.print_code in ('" + dybh + "')")+
if(len(sfz) == 0,""," and tmp.user_id in ('" + sfz + "')") +
if(len(khmc) == 0,""," and tmp.customer_name in ('" + khmc + "')") +
if(len(strxm) == 0,""," and tmp.user_name in ('" + strxm + "')") +
if(len(stime) == 0,""," and tmp.begin_time >= ('" + stime + "')") +
if(len(etime) == 0,""," and tmp.end_time < ('" + etime + "')"),
"select * from newsoft_cs.oa_wt_view WHERE 1=1"+
RiveryLv5中级互助
发布于2022-9-2 09:24(编辑于 2022-9-2 09:27)
因为后面的${}条件实际上是一样的,所以只需要对不一样的部分判断就行了的,亲测没问题
${if((OA='1'),"select * from newsoft_cs.oa_wt_temp tmp
WHERE 1=1"
weibwLv7高级互助
发布于2022-9-2 09:07(编辑于 2022-9-2 09:24)
  • 758浏览人数
  • 最后回答于:2022-9-2 09:27
