A fatal error has been detected by the Java Runtime Environment: ## EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x000000002ad1802e, pid=356, tid=0x0000000000001b70## JRE version: Java(TM) SE Runtime Environment (8.0_144-b01) (build 1.8.0_144-b01)# Java VM: Java HotSpot(TM) 64-Bit Server VM (25.144-b01 mixed mode windows-amd64 )# Problematic frame:# C [tcnative-1.dll+0x802e]## Core dump written. Default location: D:\apache-tomcat-8.0.45\bin\hs_err_pid356.mdmp## An error report file with more information is saved as:# D:\apache-tomcat-8.0.45\bin\hs_err_pid356.log ## If you would like to submit a bug report, please visit:# http://bugreport.java.com/bugreport/crash.jsp# The crash happened outside the Java Virtual Machine in native code.# See problematic frame for where to report the bug. |
