${if(len(PLAN_TYPE)==0,\"\",\"andPLAN_TYPE=\'\"+
${if(len(PLAN_TYPE)==0," "," and PLAN_TYPE = '" + PLAN_TYPE + "' ")} 这个可以和 SUBSTR(PLAN_TYPE,1,8)  结合吗
FineReport HMvTVzmj 发布于 2022-9-15 09:10
发布于2022-9-15 09:12
可以的啊
${if(len(PLAN_TYPE)==0," "," and SUBSTR(PLAN_TYPE,1,8) = '" + PLAN_TYPE + "' ")}
yzm339714Lv6中级互助
发布于2022-9-15 09:11
可以啊,你想怎么结合
  • 226浏览人数
  • 最后回答于:2022-9-15 09:12
