动态切换年月日查询报表问题
语句如下:
select ResultFile as '品种',BatchId as '批号',TestEnv as '测试状态',count(1) as '测试总量'
,count(case when  Result=1 then 1 end ) as '合格量'
,convert(decimal(18,4),(count(case when  Result=1 then 1 end) / (count(1)+0.0))) as '总良率'
,convert(decimal(18,4),(count(case when  IthResult=1 then 1 end) / (count(1)+0.0))) as ' Ith良率'
,convert(decimal(18,4),(count(case when  PfResult=1 then 1 end) / (count(1)+0.0))) as ' Pf良率'
,convert(decimal(18,4),(count(case when  SEResult=1 then 1 end) / (count(1)+0.0))) as ' SE良率'
,convert(decimal(18,4),(count(case when  RsResult=1 then 1 end) / (count(1)+0.0))) as ' Rs良率'
,convert(decimal(18,4),(count(case when  VfResult=1 then 1 end) / (count(1)+0.0))) as ' Vf良率'
,0 as 'Im良率',0 as 'Idk判定'
,convert(decimal(18,4),(count(case when  KinkResult=1 then 1 end) / (count(1)+0.0))) as ' Kink良率'
,convert(decimal(18,4),(count(case when  LostResult=1 then 1 end) / (count(1)+0.0))) as ' SE_Lost良率'
,convert(decimal(18,4),(count(case when  bSm0=1 then 1 end) / (count(1)+0.0))) as ' SMSR0良率'
,convert(decimal(18,4),(count(case when  bSm1=1 then 1 end) / (count(1)+0.0))) as ' SMSR1良率'
,0 as 'SMSR2良率'
,convert(decimal(18,4),(count(case when  bWd=1 then 1 end) / (count(1)+0.0))) as ' WavDiff良率'
,convert(decimal(18,4),(count(case when  PbResult=1 then 1 end) / (count(1)+0.0))) as ' Stop_band良率'
From CHIP_TEST
where 1=1
group by ResultFile,BatchId,TestEnv
参数条件如下:
${if(type=="日报"," and date(TesTime )='"+ date +"'",
if(type=="月报"," and strftime('%m',CHIP_TEST.TesTime )='"+ month+"'"+" and strftime('%Y',CHIP_TEST.
TesTime )='"+ year+"'"," and strftime('%Y',CHIP_TEST.TesTime )='"+ year+"'"))}
参数不论放 1=1 后面 还是放group by 后面 都报错1=1 后面报 strftime 不存在函数group by  报错  and 错误
FineReport SQL six28 发布于 2022-9-23 10:25 (编辑于 2022-9-23 10:27)
发布于2022-9-23 10:27(编辑于 2022-9-23 10:41)
什么数据库 没得这个函数
  • six28 six28(提问者) https://help.fanruan.com/finereport/doc-view-408.html 官方给的哦
    2022-09-23 10:28
  • six28 six28(提问者) SQL
    2022-09-23 10:29
  • Z4u3z1 Z4u3z1 回复 six28(提问者) ms sqlserve?mysql?oracle等等都是SQL.......
    2022-09-23 10:31
  • six28 six28(提问者) 回复 Z4u3z1 MS SQL
    2022-09-23 10:37
  • Z4u3z1 Z4u3z1 回复 six28(提问者) strftime(\'%m\',CHIP_TEST.TesTime ) 改成 DATEPART(MONTH,CHIP_TEST.TesTime)
    2022-09-23 10:41
格调Lv6初级互助
发布于2022-9-23 10:29
sql中用switch函数即可
  • 324浏览人数
  • 最后回答于:2022-9-23 10:41
