安装帆软报表设计器插件后,设计器无法启动。
SLF4J: Failed to load class "org.slf4j.impl.StaticLoggerBinder".
SLF4J: Defaulting to no-operation (NOP) logger implementation
SLF4J: See http://www.slf4j.org/codes.html#StaticLoggerBinder for further details.
Exception in thread "AWT-EventQueue-0" java.lang.NoClassDefFoundError: com/fr/design/dialog/BasicPane$NamePane
at java.lang.Class.getDeclaredMethods0(Native Method)
at java.lang.Class.privateGetDeclaredMethods(Unknown Source)
at java.lang.Class.getDeclaredMethod(Unknown Source)
at java.awt.Component.isCoalesceEventsOverriden(Unknown Source)
at java.awt.Component.access$500(Unknown Source)
at java.awt.Component$3.run(Unknown Source)
at java.security.AccessController.doPrivileged(Native Method)
at java.awt.Component.checkCoalescing(Unknown Source)
at java.awt.Component.<init>(Unknown Source)
at java.awt.Container.<init>(Unknown Source)
at javax.swing.JComponent.<init>(Unknown Source)
at javax.swing.JPanel.<init>(Unknown Source)
at com.fr.design.dialog.BasicPane.<init>(Unknown Source)
at com.fr.design.mainframe.DockingView.<init>(Unknown Source)
at com.fr.design.data.BasicTableDataTreePane.<init>(Unknown Source)
at com.fr.plugins.dsgroup.CustomTableDataTreePane.<init>(CustomTableDataTreePane.java:107)
at com.fr.plugins.dsgroup.CustomTableDataTreePane.<clinit>(CustomTableDataTreePane.java:68)
at com.fr.plugins.dsgroup.TableDataPaneProcessorImpl.createTableDataTreePane(TableDataPaneProcessorImpl.java:20)
at com.fr.design.data.datapane.TableDataTreePane.getInstance(Unknown Source)
at com.fr.design.mainframe.DesignerFrame.refreshEnv(Unknown Source)
at com.fr.design.utils.DesignUtils$3.run(Unknown Source)
at java.awt.event.InvocationEvent.dispatch(Unknown Source)
at java.awt.EventQueue.dispatchEventImpl(Unknown Source)
at java.awt.EventQueue.access$500(Unknown Source)
at java.awt.EventQueue$3.run(Unknown Source)
at java.security.ProtectionDomain$1.doIntersectionPrivilege(Unknown Source)
at java.awt.EventQueue.dispatchEvent(Unknown Source)
at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
at java.awt.EventDispatchThread.run(Unknown Source)
Caused by: java.lang.ClassNotFoundException: com.fr.design.dialog.BasicPane$NamePane
at com.fr.plugin.A.F.C$1.A(Unknown Source)
at com.fr.plugin.A.F.C$1.run(Unknown Source)
at com.fr.plugin.A.F.C.findClass(Unknown Source)
at java.lang.ClassLoader.loadClass(Unknown Source)
... 38 more
Exception in thread "AWT-EventQueue-0" java.lang.NoClassDefFoundError: Could not initialize class com.fr.plugins.dsgroup.CustomTableDataTreePane
at com.fr.design.mainframe.DesignerFrameFileDealerPane.setCurrentEditingTemplate(Unknown Source)
at com.fr.design.mainframe.DesktopCardPane.showJTemplate(Unknown Source)
at com.fr.design.mainframe.DesignerFrame.addAndActivateJTemplate(Unknown Source)
at com.fr.design.mainframe.DesignerFrame.openTemplate(Unknown Source)
at com.fr.start.BaseDesigner.openFile(Unknown Source)
at com.fr.start.BaseDesigner.showDesignerFrame(Unknown Source)
at com.fr.start.BaseDesigner.initLookAndFeel(Unknown Source)
at com.fr.start.BaseDesigner.init(Unknown Source)
at com.fr.start.BaseDesigner.<init>(Unknown Source)
at com.fr.start.Designer.<init>(Unknown Source)
at com.fr.start.Designer.main(Unknown Source)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at com.exe4j.runtime.LauncherEngine.launch(LauncherEngine.java:62)
at com.exe4j.runtime.WinLauncher.main(WinLauncher.java:101)
at com.install4j.runtime.launcher.WinLauncher.main(WinLauncher.java:16)
FineReport honliv 发布于 2019-8-7 14:23
发布于2019-8-7 14:26
楼主:推测是“插件版本”与设计器使用的“jar兼容性”有问题。先把插件删掉,升级下jar版本再安装该插件再试试!
  • 385浏览人数
  • 最后回答于:2019-8-7 14:26
