怎末使PRO_AMO字段后面跟上上年年初年末的金额
SQL ROBOT 发布于 2022-11-7 12:04
悬赏:0 F币 + 添加悬赏
发布于2022-11-7 12:36
是要年初还是年末?已上年年初为例
SELECT a.*,b.pro_amo as 年初,c.pro_amo as 年末 FROM tablea a
left join (
select * from tablea where substr(pro_date,6,2)='01'
) b on substr(a.pro_date,1,4)=substr(b.pro_date,1,4)
left join (
select * from tablea where substr(pro_date,6,2)='12'
) c on substr(a.pro_date,1,4)=substr(c.pro_date,1,4)-1
发布于2022-11-7 12:25
这个不是有写了吗,你要年初年末稍微修改下
left join (
left join (
  • 245浏览人数
  • 最后回答于:2022-11-7 12:36
