如何添加mysql\'的这个sql的索引
select a.id,
a.plan_num,
a.material_code,
a.material_desc,
a.unit,
a.con_num,
a.send_place,
a.ccz,
a.contract_num,
a.dcplan_sh,
a.plan_sendrq,
a.Shipper,
a.Shipper_tel,
a.dalei,
d.isDirect,
d.region,
e.supplier_name
from
delivery_plan a
left join (select order_num,order_row_num,supplier_name from material_china_order where document_date>='2022-01-01' and document_date<='2022-12-31') e
on a.pzbh=e.order_num
and a.pzhxm=e.order_row_num
left join ( select purchase_order_num,purchase_order_line_item_code,isDirect,region from material_china_plan where submission_date>='2022-01-01' and submission_date<='2022-12-31') d
on a.pzbh=d.purchase_order_num
and a.pzhxm=d.purchase_order_line_item_code
left join delivery_power b on a.dalei=b.qx
and a.zt='2'
and a.ccz='xxx'
and b.czz='xxx'
and b.code='80598231'
order by plan_sendrq desc
如题,d和e中数据较多,现有一个这样的sql ,如何增加索引可以提升数据查询速度
SQL 用户DRQXF9153762 发布于 2022-12-14 11:26
悬赏:0 F币 + 添加悬赏
用户DRQXF9153762Lv3初级互助
发布于2022-12-14 16:02
将联查表的where放到总查询处 同时将联查表的查询内容放置索引 即可提升速度
牛~~~Lv6中级互助
发布于2022-12-14 11:35
你这个 d、e 查询的周期长,数据量级多的话,建议按照日期做分区处理,其他的没啥建议的
  • 用户DRQXF9153762 用户DRQXF9153762(提问者) 为啥不能增加索引提升速度呢0.0
    2022-12-14 11:40
  • 牛~~~ 牛~~~ 回复 用户DRQXF9153762(提问者) 索引不是加的越多越好的。虽然索引本身就是为了提高表的查询效率,但是复杂的SQL、多表的关联本身就会影响性能。
    2022-12-14 12:43
ss2021Lv5见习互助
发布于2022-12-14 16:33
e的order_num,order_row_num 列上创建索引,d的purchase_order_num,purchase_order_line_item_code列上创建索引 a表的pzbh 和pzhxm 列上创建索引 另外  submission_date>='2022-01-01' and submission_date<='2022-12-31' 这个条件加在最下面的where 里试试
  • 305浏览人数
  • 最后回答于:2022-12-14 16:33
