连接sqlservel问题
com.fr.third.alibaba.druid.pool.GetConnectionTimeoutException: wait millis 10009, active 0, maxActive 50, creating 1, createElapseMillis 10009
com.fr.third.alibaba.druid.pool.DruidDataSource.getConnectionInternal(DruidDataSource.java.1839)
com.fr.third.alibaba.druid.pool.DruidDataSource.getConnectionDirect(DruidDataSource.java.1483)
com.fr.third.alibaba.druid.pool.DruidDataSource.getConnection(DruidDataSource.java.1463)
com.fr.third.alibaba.druid.pool.DruidDataSource.getConnection(DruidDataSource.java.1452)
com.fr.third.alibaba.druid.pool.DruidDataSource.getConnection(DruidDataSource.java.100)
com.fr.stable.pool.DataSourceAdapter.getConnection(DataSourceAdapter.java.60)
com.fr.stable.pool.DataSourceAdapterInvertWrapper.getConnection(DataSourceAdapterInvertWrapper.java.153)
com.fr.cbb.dialect.datasource.pool.DataSourceWrapper.getConnection(DataSourceWrapper.java.263)
com.fr.cbb.dialect.datasource.pool.MemoryConnection.create(MemoryConnection.java.187)
com.fr.cbb.dialect.datasource.DataSourceFactory.getConnection(DataSourceFactory.java.71)
com.fr.data.pool.MemoryConnection.create(MemoryConnection.java.125)
com.fr.data.auth.Authentication.authenticate(Authentication.java.50)
com.fr.data.auth.normal.NormalAuthentication.authenticate(NormalAuthentication.java.50)
com.fr.data.impl.JDBCDatabaseConnection.createConnection(JDBCDatabaseConnection.java.343)
com.fr.data.impl.JDBCDatabaseConnection.testConnection(JDBCDatabaseConnection.java.322)
com.fr.data.operator.DataOperator$8.call(DataOperator.java.-1)
java.util.concurrent.FutureTask.run(FutureTask.java.266)
java.util.concurrent.Executors$RunnableAdapter.call(Executors.java.511)
java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java.1149)
java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java.624)
java.lang.Thread.run(Thread.java.748)
FineReport 入海 发布于 2023-1-5 16:53
发布于2023-1-5 16:57
SQL Server数据连接常见问题-https://help.fanruan.com/finereport/doc-view-306.html
或者看看是不是驱动jar包不对
[平台]Microsoft SQL Server数据连接-https://help.fanruan.com/finereport/doc-view-2559.html
  • 256浏览人数
  • 最后回答于:2023-1-5 16:57
