求助,预览后数据集执行sql报内存不足,实际数据库可以正常执行且才50G,这是什么原因呢?
错误代码:11300001 数据集配置错误<br>Query:<br>错误代码:11300001 数据集配置错误<br>java.sql.SQLException: [Simba][ImpalaJDBCDriver](500051) ERROR processing query/statement. Error Code: 0, SQL state: Rejected query from pool root.extgroup: request memory needed 1216.55 GB is greater than pool max mem resources 920.00 GB.<br><br>Use the MEM_LIMIT query option to indicate how much memory is required per node. The total memory needed is the per-node MEM_LIMIT times the number of nodes executing the query. See the Admission Control documentation for more information.<br>
FineReport SQL 苑苑苑苑苑 发布于 2023-2-6 16:15
发布于2023-2-6 16:18
请求的内存要1216GB???这是什么请求,有多少数据??这个表?不加的参数的吗
其实我是宁采臣Lv4见习互助
发布于2023-2-6 17:22
你要不用fineBI做,report不适合大数据量
  • 347浏览人数
  • 最后回答于:2023-2-6 17:22
