kettle连接数据库报错
错误连接数据库 [ads] : org.pentaho.di.core.exception.KettleDatabaseException:
Error occurred while trying to connect to the database
Error connecting to database: (using class com.microsoft.sqlserver.jdbc.SQLServerDriver)
通过端口 1433 连接到主机 ${aos_dw_host} 的 TCP/IP 连接失败。错误:“null。请验证连接属性。确保 SQL Server 的实例正在主机上运行,且在此端口接受 TCP/IP 连接,还要确保防火墙没有阻止到此端口的 TCP 连接。”。
at org.pentaho.di.core.database.Database.normalConnect(Database.java:472)
at org.pentaho.di.core.database.Database.connect(Database.java:370)
at org.pentaho.di.core.database.Database.connect(Database.java:341)
at org.pentaho.di.core.database.Database.connect(Database.java:331)
at org.pentaho.di.core.database.DatabaseFactory.getConnectionTestReport(DatabaseFactory.java:80)
at org.pentaho.di.core.database.DatabaseMeta.testConnection(DatabaseMeta.java:2783)
at org.pentaho.ui.database.event.DataHandler.testDatabaseConnection(DataHandler.java:597)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at org.pentaho.ui.xul.impl.AbstractXulDomContainer.invoke(AbstractXulDomContainer.java:313)
at org.pentaho.ui.xul.impl.AbstractXulComponent.invoke(AbstractXulComponent.java:157)
at org.pentaho.ui.xul.impl.AbstractXulComponent.invoke(AbstractXulComponent.java:141)
at org.pentaho.ui.xul.swt.tags.SwtButton.access$500(SwtButton.java:43)
at org.pentaho.ui.xul.swt.tags.SwtButton$4.widgetSelected(SwtButton.java:137)
at org.eclipse.swt.widgets.TypedListener.handleEvent(Unknown Source)
at org.eclipse.swt.widgets.EventTable.sendEvent(Unknown Source)
at org.eclipse.swt.widgets.Display.sendEvent(Unknown Source)
at org.eclipse.swt.widgets.Widget.sendEvent(Unknown Source)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Unknown Source)
at org.eclipse.swt.widgets.Display.readAndDispatch(Unknown Source)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:820)
at org.eclipse.jface.window.Window.open(Window.java:796)
at org.pentaho.di.ui.xul.KettleDialog.show(KettleDialog.java:80)
at org.pentaho.di.ui.xul.KettleDialog.show(KettleDialog.java:47)
at org.pentaho.di.ui.core.database.dialog.XulDatabaseDialog.open(XulDatabaseDialog.java:116)
at org.pentaho.di.ui.core.database.dialog.DatabaseDialog.open(DatabaseDialog.java:60)
at org.pentaho.di.ui.spoon.delegates.SpoonDBDelegate.editConnection(SpoonDBDelegate.java:96)
at org.pentaho.di.ui.spoon.Spoon.doubleClickedInTree(Spoon.java:3108)
at org.pentaho.di.ui.spoon.Spoon.doubleClickedInTree(Spoon.java:3043)
at org.pentaho.di.ui.spoon.Spoon.access$2300(Spoon.java:361)
at org.pentaho.di.ui.spoon.Spoon$26.widgetDefaultSelected(Spoon.java:6184)
at org.pentaho.di.ui.spoon.Spoon.readAndDispatch(Spoon.java:1366)
at org.pentaho.di.ui.spoon.Spoon.waitForDispose(Spoon.java:8022)
at org.pentaho.di.ui.spoon.Spoon.start(Spoon.java:9277)
at org.pentaho.di.ui.spoon.Spoon.main(Spoon.java:692)
at org.pentaho.commons.launcher.Launcher.main(Launcher.java:92)
Caused by: org.pentaho.di.core.exception.KettleDatabaseException:
at org.pentaho.di.core.database.Database.connectUsingClass(Database.java:585)
at org.pentaho.di.core.database.Database.normalConnect(Database.java:456)
... 47 more
Caused by: com.microsoft.sqlserver.jdbc.SQLServerException: 通过端口 1433 连接到主机 ${aos_dw_host} 的 TCP/IP 连接失败。错误:“null。请验证连接属性。确保 SQL Server 的实例正在主机上运行,且在此端口接受 TCP/IP 连接,还要确保防火墙没有阻止到此端口的 TCP 连接。”。
at com.microsoft.sqlserver.jdbc.SQLServerException.makeFromDriverError(SQLServerException.java:190)
at com.microsoft.sqlserver.jdbc.SQLServerException.ConvertConnectExceptionToSQLServerException(SQLServerException.java:241)
at com.microsoft.sqlserver.jdbc.SocketFinder.findSocket(IOBuffer.java:2243)
at com.microsoft.sqlserver.jdbc.TDSChannel.open(IOBuffer.java:491)
at com.microsoft.sqlserver.jdbc.SQLServerConnection.connectHelper(SQLServerConnection.java:1309)
at com.microsoft.sqlserver.jdbc.SQLServerConnection.login(SQLServerConnection.java:991)
at com.microsoft.sqlserver.jdbc.SQLServerConnection.connect(SQLServerConnection.java:827)
at com.microsoft.sqlserver.jdbc.SQLServerDriver.connect(SQLServerDriver.java:1012)
at java.sql.DriverManager.getConnection(DriverManager.java:664)
at java.sql.DriverManager.getConnection(DriverManager.java:270)
at org.pentaho.di.core.database.Database.connectUsingClass(Database.java:558)
... 48 more
主机名       : ${aos_dw_host}
端口           : 1433
数据库名:aos_ads
FineReport sgq3256 发布于 2023-2-7 15:44
IndustryPaysLv6见习互助
发布于2023-2-7 16:01(编辑于 2023-2-7 16:04)
微信截图_20230207155956.png数据库连接错误,${aos_dw_host}数据库指向文件配置地址找不到,查看kettle.properties该文件配置信息是否有误,没有则添加文件;
发布于2023-2-7 15:45
你主机名设置的是变量,你没有给变量设置对应的值,所以找不到主机
  • 402浏览人数
  • 最后回答于:2023-2-7 16:04
