sqlserver如何拼接字符串并将字符串转换成字段,因为有太多的字段需要改,所以想简单化
予i 发布于 2023-2-7 17:09 (编辑于 2023-2-7 17:17)
发布于2023-2-7 17:10(编辑于 2023-2-8 09:19)
https://blog.csdn.net/m0_49844045/article/details/122350226 行转列参考
SELECT (case when a.colorder=1 then d.name else null end) 表名, ( d.name) 表名2,
a.colorder 字段序号,a.name 字段名,
CONCAT(a.name,'_TZ') [NEW_],
(case when COLUMNPROPERTY( a.id,a.name,'IsIdentity')=1 then '√'else '' end) 标识,
(case when (SELECT count(*) FROM sysobjects
WHERE (name in (SELECT name FROM sysindexes
WHERE (id = a.id) AND (indid in
(SELECT indid FROM sysindexkeys
WHERE (id = a.id) AND (colid in
(SELECT colid FROM syscolumns WHERE (id = a.id) AND (name = a.name)))))))
AND (xtype = 'PK'))>0 then '√' else '' end) 主键,b.name 类型,a.length 占用字节数,
COLUMNPROPERTY(a.id,a.name,'PRECISION') as 长度,
isnull(COLUMNPROPERTY(a.id,a.name,'Scale'),0) as 小数位数,(case when a.isnullable=1 then '√'else '' end) 允许空,
isnull(e.text,'') 默认值,isnull(g.[value], ' ') AS [说明]
FROM syscolumns a
left join systypes b on a.xtype=b.xusertype
inner join sysobjects d on a.id=d.id and d.xtype='U' and d.name<>'dtproperties'
left join syscomments e on a.cdefault=e.id
left join sys.extended_properties g on a.id=g.major_id AND a.colid=g.minor_id
left join sys.extended_properties f on d.id=f.class and f.minor_id=0
--where b.name is not null
WHERE d.name='Table_GJJ_TZ' --如果只查询指定表,加上此条件 如果去掉则是查询全部的
--order by a.id,a.colorder
--SELECT * FROM Table_GJJ_TZ
  • 予i 予i(提问者) 审题哥们
    2023-02-07 17:11
  • 予i 予i(提问者) 太复杂了哥们,我想的就很简单
    2023-02-07 17:26
  • Z4u3z1 Z4u3z1 回复 予i(提问者) 有可能我想复杂了,要下班了。再消化消化你的需求
    2023-02-07 17:27
  • 予i 予i(提问者) 回复 Z4u3z1 应该是这种ZBZ+\\\'${LX}\\\',LX这个参数传空值或者_XZ做一个拼接
    2023-02-08 08:34
  • 予i 予i(提问者) 回复 Z4u3z1 SELECT DW, YP, KM AS PRO_ID, (CASE WHEN 1=2 THEN \'ZBZ\'+\'\' ELSE \'ZBZ\'+\'_XZ\' END) AS ZB -- 2023-03-07替换年初值与修正值动态参数 FROM INPUT_YSFJ_ZJB
    2023-02-08 08:50
FANSHUzwLv5中级互助
发布于2023-2-7 17:18
‘${lx}’+'要加的内容'  as  ZB
  • 予i 予i(提问者) 这种写的报错呀
    2023-02-08 08:30
  • 予i 予i(提问者) 应该是这种ZBZ+\'${LX}\',LX这个参数传空值或者_XZ做一个拼接
    2023-02-08 08:33
  • 415浏览人数
  • 最后回答于:2023-2-8 09:19
