怎么把单元格加进数据集里,单元格的值为(1,2,3,4)这种,所以使用IN要用replac加上单引号
select
 from
  DM.CT_PRODUCT_PJLGD
  WHERE (1=1)
  ${if(len('${B7}') = 0,"","AND FID in ('" +  REPLACE('${B7}',",","','") + "')")}
上面这个有问题
FineReport 帆软用户TQ6gXR9SO6 发布于 2023-2-8 10:56
发布于2023-2-8 10:57(编辑于 2023-2-8 10:59)
select
 from
  DM.CT_PRODUCT_PJLGD
  WHERE (1=1)
  ${if(len(B7) = 0,"","AND FID in ('" +  REPLACE(B7,",","','") + "')")}
分别多了 $ 花括号 ' 三个字符
  • 196浏览人数
  • 最后回答于:2023-2-8 10:59
