数据集${if(,,,)}中,如何正确放置$getuserdepartments(1),以及嵌套?
求问,数据集中,在${if()}中,如何正确放置引用$getuserdepartments(1),以及在${if()}中嵌套使用$if()的正确写法是怎么样的?
${if(条件,"select * from A where clunm=$getuserdepartments(1)","select * from B where 1=1$if(条件),“and clunm=%getuserdepartments(1)”,"and clumn2= xxx"")}大概结构是这个样子
FineReport Maxizzz 发布于 2023-3-1 10:25 (编辑于 2023-3-1 10:31)
发布于2023-3-1 10:26(编辑于 2023-3-1 10:34)
首先你的 判断逻辑是什么?否则无法知晓怎么算正确
${if(条件1,"select * from A where clunm='"+getuserdepartments(1)+"'","select * from B where 1=1 "+if(统计2,"and clunm='"+getuserdepartments(1)+"'","and clumn2= xxx"))}
  • Maxizzz Maxizzz(提问者) ${if(条件,\"select * from A where clunm=$getuserdepartments(1)\",\"select * from B where 1=1 $if(条件),“and clunm=%getuserdepartments(1)”,\"and clumn2= xxx\" \")} 大概结构是这个样子
    2023-03-01 10:30
  • Z4u3z1 Z4u3z1 回复 Maxizzz(提问者) 上面补充了
    2023-03-01 10:34
发布于2023-3-1 10:32(编辑于 2023-3-1 10:35)
举例
${if(a=="1"," and 部门1='"+getuserdepartments(1)+",",if(b=="1",""," and 部门2='"+getuserdepartments(1)+","))}
${if(条件,"select * from A where clunm='"+getuserdepartments(1)+"'","select * from B where 1=1"+if(条件,“and clunm='"+getuserdepartments(1)+"'”,"and clumn2= 'xxx'"))}
  • 409浏览人数
  • 最后回答于:2023-3-1 10:35
