fr11推荐关闭swap内存分区以后经常出错
OpenJDK 64-Bit Server VM warning: INFO: os::commit_memory(0x00000002c0000000, 14        316732416, 0) failed; error='Cannot allocate memory' (errno=12)
# There is insufficient memory for the Java Runtime Environment to continue.
# Native memory allocation (mmap) failed to map 14316732416 bytes for committing        reserved memory.
# An error report file with more information is saved as:
# /home/tomcat/bin/hs_err_pid3892.log
FineReport wk9811 发布于 2023-5-8 10:40 (编辑于 2023-5-8 11:06)
发布于2023-5-8 10:46
那这个直接就在开启把
最近出现低版本java的jvm内存老不够用
  • wk9811 wk9811(提问者) 下载的是官方tomcat最新版。。
    2023-05-08 11:02
  • snrtuemc snrtuemc 回复 wk9811(提问者) 最新版他也是有时间的,你需要手动升级本级jdk,或者打开swap把
    2023-05-08 11:06
  • wk9811 wk9811(提问者) 回复 snrtuemc 打开。swap感觉性能没差太多
    2023-05-09 13:32
  • snrtuemc snrtuemc 回复 wk9811(提问者) 那就再加大tomcat的内存把
    2023-05-09 13:33
  • 393浏览人数
  • 最后回答于:2023-5-8 11:06
