现在的J是这样的,想再加一个条件,让份额小于7的不显示箭头,要怎么改 var cl = this.seriesName; var sql = "map('"+cl+"','排量当年份额情况',2,5)"; var value1 = FR.remoteEvaluate(sql); var value=(Number(value1)*100).toFixed(0); if(value <0){ return '<p><img src ="../../help/picture/jiantou/向下箭头.png" width="15" height="25" align="middle"></p>'; } else { return '<p><img src ="../../help/picture/jiantou/向上箭头.png" width="15" height="25" align="middle"></p>'; } } |
最佳回答 |
