function(){ var cl = this.seriesName; var sql = "map('"+cl+"','排量当年份额情况',2,5)"; var value1 = FR.remoteEvaluate(sql); var value=(Number(value1)*100).toFixed(0); if(value <0){ return ' <img src ="../../help/picture/arrows/arrows-down-green.png" width="15" height="25" align="middle"> ';} else if (value >0) { return ' <img src ="../../help/picture/arrows-up-red.png" width="15" height="25" align="middle"> ';} else {return ""} } 自定义的标签在设计器预览可以预览,但是挂到决策平台却显示不出来,可能是什么原因?怎么解决? |
