sql语句帮忙看下,想要今年就显示1-5月,以前年份就显示1-12月,这个语句要怎么修改
pv2为参数,接收具体年份,例如2023
select
  t.*
from
(SELECT
 lpad(t.month,2,0) as FMONTH,
 t.month || '月实际产量' as MONTHVIEW
FROM
(select level month from dual connect by LEVEL<13)t
)t
where (1=1)
 ${if(pv2 = to_char(SYSDATE,'yyyy'),"AND t.FMONTH<= SUBSTR(to_char(SYSDATE,'yyyy-mm'),6,2)","")}
SQL 李蓉9 发布于 2023-5-31 10:32 (编辑于 2023-5-31 10:36)
悬赏:0 F币 + 添加悬赏
李蓉9Lv3见习互助
发布于2023-5-31 11:13
with year as(
   SELECT
   a.YEAR,
CASE WHEN a.YEAR = TO_CHAR(SYSDATE,'YYYY') THEN SUBSTR(TO_CHAR(SYSDATE,'YYYY-MM'), 6, 2) else '12' end as pd
FROM
(select to_char(sysdate,'YYYY')-LEVEL+1 YEAR FROM DUAL CONNECT BY LEVEL<=13)a
select
  t.FMONTH,
t.MONTHVIEW
from
(SELECT
FROM
(select level month from dual connect by LEVEL <13)t
)t,
  select * from year
where (1=1)
        ${if(len(pv2) = 0,"","and YEAR='" +pv2+ "'")}
) a
where (1=1)
  t.FMONTH<=a.PD
  • 0关注人数
  • 183浏览人数
  • 最后回答于:2023-5-31 11:13
